subs not working
subs not working
Postby 88.4ageGT » Fri Mar 11, 2011 7:22 pm
i was out on a drive and my subs just stoped working
theres def power to the amp and the remote to
i checked all the connections with the wires to and from the amp
and the rca and still nothing...
any ideas???
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby DeeCee » Sat Mar 12, 2011 6:20 pm
are the lights on the amp going? check fuses and make sure that there are no stray wires touching metal
GT Four Adovansu
DeeCee
Postby celica_xr9145 » Sat Mar 12, 2011 8:22 pm
I had the same problem, found it to be a bad ground location and the bolt not tight enough to the chassis.
celica_xr9145
Postby 88.4ageGT » Sat Mar 12, 2011 10:04 pm
DeeCee wrote:are the lights on the amp going? check fuses and make sure that there are no stray wires touching metal
yup checked all that
AE92 4age GTi
88.4ageGT
Postby DeeCee » Sat Mar 12, 2011 10:57 pm
check resistance on coils with multimeter.
if the subs are toast there may be a burnt smell to the coils. Test by smell or pushing the cones in and out and seeing if there is friction if the coils are burnt to crisp.
Alternatively pull sub and test another unit, either sub on another amp or another sub on the amp.
Check all settings on headunit and amp. Check connections aren't loose behind headunit.
GT Four Adovansu
DeeCee
Postby simonlenihan » Sun Mar 13, 2011 8:26 am
So the lights on the amp are on?
What impedance do you get across the coils of the subs?
2011 Toyota Hiace ZL
1994 BMW 740iL e38
simonlenihan
Postby Mr Ree » Fri Apr 29, 2011 6:34 pm
Remove the speaker wire from the amp and get a 9V battery. Carefully touch the wires to a terminal each and watch the cone to see if the voice coil is still doing its job.
wak thud gush!
Mr Ree
Postby 88.4ageGT » Fri Apr 29, 2011 11:12 pm
i just tryed a different amp and it worked so i just through money at it and brought a fusion amp :)
AE92 4age GTi
88.4ageGT
