Principles of flight?
Can the Plane Take Off
Yes
41
48%
No
31
36%
Flying is an unholy abomination and will result in eternal damnation for all those that attempt it
13
15%
Total votes : 85
Postby mr pad » Mon Dec 19, 2005 9:29 am
I voted no. If the conveyer is matching wheel speed then the plane is not moving + no wind = no lift created on wings.
Correct?
mr pad
Postby Mr Revhead » Mon Dec 19, 2005 9:33 am
nope. have a read, and a think...
the key is what makes a plane move
Postby mr pad » Mon Dec 19, 2005 9:40 am
Mr Revhead wrote:nope. have a read, and a think...
An engine of sorts. But it makes no mention of one, so nothing to factor in.
mr pad
Postby Mr Revhead » Mon Dec 19, 2005 9:42 am
think reeeeeal basic, how does a plane move.....
like a car? like a boat? hmmmmmmm
Postby pidge » Mon Dec 19, 2005 10:30 am
mr pad wrote:An engine of sorts. But it makes no mention of one, so nothing to factor in.
All functioning aeroplanes have either prop or jet engines.
Aeroplanes without engines are either grounded, or called "gliders" ;)
Since the questions says the aeroplane is "ready to take off", the aeroplane having engines seems to be a reasonable assumption to make.
pidge
Postby mr pad » Mon Dec 19, 2005 10:57 am
pidge wrote:Since the questions says the aeroplane is "ready to take off", the aeroplane having engines seems to be a reasonable assumption to make.
Well if thats the case the plane will move foward, and then fly. 8)
Damn that wasn't so hard :lol:
mr pad
Postby fivebob » Mon Dec 19, 2005 11:03 am
blitza wrote:and fivebob pisses himself...
Indeed I am. But it's still well short of the several hundred pages I've seen on this topic on other forums (without reaching a conclusion), so keep going :lol: :lol: :lol:
FWIW I don't know the answer to this problem, or indeed if there is an answer at all. To me the definintion of the problem is in itself impossible.
In order for the belts to move the wheel must first rotate, as it is not driven directly like a car, the plane must obtain forward motion for this to happen, so no matter how fast the belt moves the wheel is always spinning faster, so the belt is instantly moving at infinite speed, while the planes wheels are spinning at infinitity plus a bit more and the plane is still moving forward.
If anything I'm of the opinion that the plane might take off, if not due to the forward motion of the aircraft, then due to the airstream created by the moving belt, or simply by having a enormous amount of tyre slip.
Postby RomanV » Mon Dec 19, 2005 11:16 am
Indeed I am. But it's still well short of the several hundered pages I've seen on this topic on other forums (without reaching a conclusion), so keep going
Bastard. :twisted::twisted:
I disagree. I think that the relationship between the belt and the wheel are like two gears meshed together... if you turn one gear, the other turns too at the same time.
It specifically states that the conveyor travels at the same speed as the wheels, not a fraction faster or slower.
The belt would not travel at infinite speed... as the belt (according to the rules) only travels at the speed of the plane(relative to the ground) times 2. Well the belt WOULD travel at infinite speed, but only if the plane was too. :P
Postby mr pad » Mon Dec 19, 2005 11:23 am
fivebob wrote:so no matter how fast the belt moves the wheel is always spinning faster, so the belt is instantly moving at infinite speed, while the planes wheels are spinning at infinitity plus a bit more and the plane is still moving forward.
Thats where I was unsure. The question is too vague for a positive answer. You can say "if this is, and it could that" but finding a definite answer seems.... tricky :lol: It seems in theory, that if this rule was applied using real world physics, well again it depends on how fast the wheels/conveyer are moving, and if moving at infinity, the plane would not take off, less like fivebob said, it was from the huge currents of air created by the belt, which can be ruled out due to the fact the question states there is no air flow. So I still say no. *head explodes*
mr pad
Postby Mr Revhead » Mon Dec 19, 2005 11:31 am
i still say yes.
because its the air that is important..... there is nothing pushing against the however many lbs of thrust being created by the engines... so it HAS to move. it moves relative to the air, thats why ground speed isnt measured in a plane, its airspeed that matters
the wheels and conveyer belt are actually seprate
think of a toy car on a conveyer belt.... if you push it it moves.
now think of your finger as the thrust.....
not quite accurate as far as the speed of the wheels go, but the principle is the same
Postby method » Mon Dec 19, 2005 12:01 pm
no_8wire wrote:Arh ok...I will succum to the others thinking...its my training I tell you....civil enginneers dont have to worry about wheels and stuff...just forces/elements... :wink:
:lol: Where did you study?
PICS UPDATED DAILY
method
Postby method » Mon Dec 19, 2005 12:06 pm
I guess there are two answes,
Theoretically Yes, it takes off but practically it isnt possible. The belt would break, or the wheels would spin so fast they would break up causing the plane to hit the belt and desintagrate or something crazy and thats IF you could build a belt like that in the first place :D
PICS UPDATED DAILY
method
Postby malc » Mon Dec 19, 2005 12:39 pm
Mr Revhead wrote:think of a toy car on a conveyer belt.... if you push it it moves.
That would not be the case in this case, because on the large conveyor the speed of the wheels is being matched at all times. If you gave the car a shove on a conveyor with a constant speed then the wheels of the car would speed up and the car would move forward. But with this large conveyor the wheels would not be able to speed up relative to the surface below it, after all it is being matched at all times.
Push matchbox car on treadmill against the motion of the belf. Can you push the car from one end to the other?
like above, it would move forward, and that is because your normal treadmill moves at a constant speed. It makes no odds whether the car is pushed very quickly or with a huge amount of thrust.
For something to move forward it must gain traction or be moving faster than the surface below. In the case of the plane, its forward speed is transfered through its wheels.
So if a plane is cruising at 200kmh flying along above ground,
and they they go full throttle,
how does the plane accelerate without the wheels on the ground.
That is because the plane got moving in the first place. It has equalled its drag, and bettered its weight.
I dont think the plane on the conveyor would move relative to the air around it or the ground beyond the conveyor, so it cannot overcome those forces.
malc
Postby RomanV » Mon Dec 19, 2005 12:47 pm
The foward motion of the plane is NOT transferred through the wheels.
As the wheels are not 'driven' like on a car.
A car moves foward by pushing against the ground... if the ground is moving backwards at the same speed as the wheels, then it will sit still.
The wheels on a plane merely reduce the friction between the plane and the ground....
I think that the 'toy car and a piece of paper' idea is the best way to demonstrate what happens.
Put the car on the paper, and push the car one way, and pull the paper under it at the same speed in the opposite direction.
The car moves, the paper moves, and the wheels move at twice the speed.
Your finger pushing the car is EXACTLY the same as if jet engines were propelling it.... it is an EXTERNAL force, that makes the wheel speed irellevant.
Postby Mr Revhead » Mon Dec 19, 2005 12:47 pm
ah but you are forgetting the thrust. it HAS to move.
as i said my example wasnt 100% accurate to the original question, but its close enough to display my point.
when you get right down to it.....
its making thrust
whats conteracting that thrust?
NOTHING
therefore it moves.
the wheels and the belt are superflorus to the question.
as ppl have already stated whats important it the air.
a lot of you are still thinking as if the wheels make the plane move, they are only there to reduce friction, they are really only bearings
Postby pidge » Mon Dec 19, 2005 12:59 pm
Newton's Three Laws of Motion
    I. Every object in a state of uniform motion remains in that state of motion unless an external force is applied to it.
    II. The relationship between an object's mass m, its acceleration a, and the applied force F is F = ma. (Note: Acceleration and force are vectors (Direction and Magnitude). The direction of the sum of the force vectors applied to an object is the same as the direction of the acceleration vector.
    III. For every action there is an equal and opposite reaction.
If you do not understand those, you cannot solve this "puzzle".
(As many of us have said) The only significant force on the aeroplane is the thrust from the engines. Therefore the aeroplane will accelerate along the converyor belt runway and take off.
pidge
Postby RomanV » Mon Dec 19, 2005 1:04 pm
Im not entirely convinced that Fivebob believes what he posted, as I think he is trying to be controversial, and doesnt want the debate to end.
After all, he DID post this up for his own twisted entertainment. :twisted:
And besides, who is stupider?
The people that think the entire force of the planes engines is transmitted as a rotational/frictional force through the wheels,(Or what ever physics concept they cant grasp at the time)
OR the people who keep on trying to talk sense into these people?
I think thats the real question here.
Postby Mr Revhead » Mon Dec 19, 2005 1:06 pm
well done dave, i think you just called everyone stupid :lol:
Postby RomanV » Mon Dec 19, 2005 1:11 pm
Except for me, cos I figured it out. :lol:
I'm S-M-R-T smart. 8)
I bet this question was initially posed by a psychologist, who was interested in studying the conflict and aggrovation that arises when people fail to understand simple concepts. :P
Postby Mr Revhead » Mon Dec 19, 2005 1:19 pm
well i did pose the question int he smoko room and two mechs did get quite wound up about it... :lol:
Return to Polls
