mr pad wrote:An engine of sorts. But it makes no mention of one, so nothing to factor in.
pidge wrote:Since the questions says the aeroplane is "ready to take off", the aeroplane having engines seems to be a reasonable assumption to make.
blitza wrote:and fivebob pisses himself...
Indeed I am. But it's still well short of the several hundered pages I've seen on this topic on other forums (without reaching a conclusion), so keep going
In order for the belts to move the wheel must first rotate, as it is not driven directly like a car, the plane must obtain forward motion for this to happen, so no matter how fast the belt moves the wheel is always spinning faster, so the belt is instantly moving at infinite speed, while the planes wheels are spinning at infinitity plus a bit more and the plane is still moving forward.
fivebob wrote:so no matter how fast the belt moves the wheel is always spinning faster, so the belt is instantly moving at infinite speed, while the planes wheels are spinning at infinitity plus a bit more and the plane is still moving forward.
If anything I'm of the opinion that the plane might take off, if not due to the forward motion of the aircraft, then due to the airstream created by the moving belt, or simply by having a enormous amount of tyre slip.
no_8wire wrote:Arh ok...I will succum to the others thinking...its my training I tell you....civil enginneers dont have to worry about wheels and stuff...just forces/elements...
Mr Revhead wrote:think of a toy car on a conveyer belt.... if you push it it moves.
now think of your finger as the thrust.....
Push matchbox car on treadmill against the motion of the belf. Can you push the car from one end to the other?
So if a plane is cruising at 200kmh flying along above ground,
and they they go full throttle,
how does the plane accelerate without the wheels on the ground.
