What turbo does your 4agte run?
What turbo do you run on a 4agte?
IHI vf series
3
8%
T3
4
10%
td04/5
16
41%
gt25/28
6
15%
ct20/26
1
3%
other...
9
23%
Total votes : 39
Postby Caveman » Wed Dec 07, 2005 5:08 pm
Brick wrote:my mate who rebuilds said if i wanted to turbo my ze he wud do it.
how much did you guys spend on your parts?
You would only need a turbo + manifold and appropriate piping.
Best get a FMIC as well as the topmount gze isnt really suited for the turbo, unless you chop one of the bars and flip it, i.e have the inlet/outlet on opposite sides.
Could be done for less than a grand
Caveman
Postby IH8TEC » Wed Dec 07, 2005 6:09 pm
viewtopic.php?t=21876
look at matt dunns post
Postby Caveman » Tue Feb 28, 2006 10:47 am
So to update this is what the manifold looks like now
Its turning out pretty good so far. All I need to do is the oil lines, intercooling pipe and dump pipe 8)
Turbo is a vf10 or rhb52. Should be good for the 200fwhp im after 8)
Caveman
Postby Kov » Tue Feb 28, 2006 7:16 pm
Looking good dylan! are you gunna be home tomorow around 6pm? I might pop by and have a look :D
4AGTE AE111 Wagon - 70% Complete
Kov
Postby IH8TEC » Tue Feb 28, 2006 7:25 pm
interesting top mounting the turbo, is it going in a rwd?
Postby Caveman » Tue Feb 28, 2006 7:39 pm
IH8TEC wrote:interesting top mounting the turbo, is it going in a rwd?
Its FWD, clearences are tight but sweet. Reason for highmount = bling
I wont be home tomorrow, I should be here on thursday after 6 though 8)
Just working on the dump pipe now.
Caveman
Postby NVD05X » Sat Mar 18, 2006 10:40 pm
sorry to drag up an old thread guys, but you NZ fella's seem to have a lot more GTE experience than anyone in sydney does!
im currently running a s14 silvia T28 on a stainless lowmount manifold.. its spooling really slow these days and i was after a few opinions..
do you guys think that exhaust wrap stuff would help retain a bit hore heat and help the spool a bit??? i've heard of people having problems with stainless cracking with that wrap over it tho.. any thoughts there?
i also had the idea that the turbo might need a rebuild..
im running a low comp gze (8.0:1) on 15psi from that setup and its making full boost by about 5000rpm... which seems a little too laggy to me..
what do you guys recommend i do?! thanks in advance for any ideas.. and here are a few pics of my manifold ect...
NVD05X
Postby IH8TEC » Sat Mar 18, 2006 10:55 pm
hey man, nice looking manifold, bazda on here had trouble with his manifold (steam tube) crackng on his old car with the heat wrap, he's advized me to stay away from it,
i'd assume it would be even more likely to crack with stainless, so my next opinion would be to get them treated with hpc or procoat,
brendon
Postby Caveman » Sat Mar 18, 2006 11:34 pm
Hey NVD05X, nice looking rolla.
From those pictures it appears the runners are of un-even length. Even length headers should spool quicker and work better overall, someone on here will be able to shed light on the topic.
I bigger dump pipe will help although that looks like a pretty meaty dump pipe already.
The obvious but most expensive option would be an aftermarket ECU, richen it off boost.
Caveman
Postby rage » Sun Mar 19, 2006 9:04 pm
in my opinion id try to bump the compression up a bit. perhaps up to 9:1
rage
Postby NVD05X » Tue Mar 21, 2006 12:09 pm
thanks for your thoughts guys... sorry i wast too clear in my last post, but i already have a microtech LTX10s running things at the moment.
ill be getting a retune pretty soon and i might bump the boost up tp 16psi to see what difference that makes.
and also i have a greddy profec b spec 2 controlling boost.
NVD05X
Postby bluemaumau » Tue Mar 21, 2006 1:57 pm
NVD05X wrote:thanks for your thoughts guys... sorry i wast too clear in my last post, but i already have a microtech LTX10s running things at the moment.
why would you bump it up 1psi? that aint gona make thatm much diff,
the pistons are strong hit 18-20psi 8)
my 2c
Postby rage » Wed Mar 22, 2006 12:34 am
upping the boost wont help with spooling or anything. NOS, antilag, compression increase, cams (maybe), external gate, electronic boost controller (a good one) will help.
rage
Postby Dell'Orto » Wed Mar 22, 2006 1:04 pm
If its spooling slower than it used to, then its probably just tired and needs a rebuild.
Otherwise, the compression is probably why it takes so long to spool, thats a reasonably sized turbo for a low comp 1600 to spin.
Postby peas » Wed Mar 22, 2006 2:47 pm
Would an external be required for a TD05h? Running something in the region of 16psi. I aren't to sure what the stock gate's limit is.
'97 Caldina GT (ST215G)
peas
Postby touge rolla » Thu Mar 23, 2006 1:45 am
^ i was under the belief that the more boost you run the less work your wastegate does, therefore stock one should suffice
touge rolla
Postby Caveman » Thu Mar 23, 2006 8:08 am
peas wrote:Would an external be required for a TD05h? Running something in the region of 16psi. I aren't to sure what the stock gate's limit is.
Nah some turbos creep if the wastegate isn't big enough. Bascially at more boost your engines flowing more air, this flows more exhaust which the wastegate has to cater for.
I know people running standard td05's with EBC at 1.3bar. It holds sweet 8) with plenty of thrashing :lol:
Caveman
Postby EVLGTZ » Mon Mar 27, 2006 8:38 am
Id go with the external on a td05 as they are reknown for overboosting.
Had serious issues with mine overboosting and now run external and EBC and get very consistent and reliable boost levels
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby NVD05X » Mon Mar 27, 2006 9:49 pm
Mmm, Boost wrote:If its spooling slower than it used to, then its probably just tired and needs a rebuild.
thats what i wanted to hear! i hope thats all it is..
im running a greddy profec b spec 2 boost controller, and that brought boost on about 500rpm sooner..
i was thinking about using the smaller rear housing from a t25 i have that came off a ca18det, with my t28 compressor housing, and getting them rebuilt and combined into a t25/28 hybrid..
do you guys think that would fix my problem?
NVD05X
Postby Stu- » Wed Apr 12, 2006 3:31 pm
I've had a HT18 on my car and it went quite well. I've now ditched that and running a To4e. Yes its got more lag but it seems to be making half decent power.
Project Thread
Stu-
Return to Polls
