TWSTD wrote:1 = ? (runs from head to air intake after filter - altho no PCV valve or anything. There is lots of oil residue in this line)
It's a crankcase breather, no PCV valve is required cause it's connected to the suction side of the intake and therefore will always flow from the head to the intake. Should have some oil in it, but if there's oil in the Thottle body as well check you compressions.
2 = ? (runs from ??? to air intake after filter)
EDIT*** should have looked first before I answered
Goes to the Idle speed control valve, supplies filtered air for idle.
3 = This is the crank case breather - complete with PCV valve - so what is 1?
#3 is also a crankcase breather, only works when the manifold is in vacuum stops excessive oil going through the turbo and I/C
4. Also i got a question about trans fluid. When i unplumb the transmission fluid cooler to get new lines made up for it do i run the risk of letting air into that system? Is it like a brake system where it needs to bled? If so how? And where do you refill trans fluid anyhow and whats the best stuff to use? (caldina GTT ST215 3SGTE).
Shouldn't need bleeding, there's nothing about it in the Celica manuals I have, but I'd suggest priming the lines from the gearbox after you re-fit the lines to the cooler.
There's a level check/filler hole on the front of the gearbox that you fill through, when it overflows it's full.
Best stuff to use, don't know with gearbox oils unless you know someone who has changed to oil and found a it better or worse it's a suck it and see approach as each box is different. IMO anything that meets the standards (API-GL5) should be ok
