Yay ae92 gtz
Yay ae92 gtz
Postby Volatile » Tue Apr 06, 2004 12:52 pm
Well after about 5months looking for a ae92 gtz,
a month ago i saw a
1990 White gtz, so i put my number on it and the guy said he will sell it in a months time, well one more week and he said he should have his new car.
it's done 130,000km
where is the best place to get it checked out? im worried if i take it to AA or vehicle testing they wont check things like compression, and condition of the s/charger.
do suspension parts off ae92 fxgt's fit on levins?
any common rust spots?
i'm sure it's a map sensor model so thats all good
any other information would be good
James
Volatile
Postby Lloyd » Tue Apr 06, 2004 1:02 pm
AA are shite. They told me bugger all about mine that I couldn't work out for myself... like the fact that it rattles. No shit.
Thats not really helpful I know, but just dont go to AA :P
Postby Ae92typeX » Tue Apr 06, 2004 1:23 pm
testing station do test compression, but really it was just another wof test I felt. pointed out a few extra bits.
Ae92typeX
Postby Mr Revhead » Tue Apr 06, 2004 2:02 pm
go to your local toyota dealer. tell them you want a prepurchase inspection done. tell them to have a good look over it for an hour or so.
just say to check the s/c etc and they should give you a very good report.
but please remember that no matter how good the inspection they cannot guarantee it wont blow up in 2 weeks.
Re: Yay ae92 gtz
Postby Banga69 » Tue Apr 06, 2004 2:11 pm
Volatile wrote:Well after about 5months looking for a ae92 gtz,
a month ago i saw a
it's done 130,000km
James
bout bloody time ur getting a gtz.
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby Volatile » Tue Apr 06, 2004 2:43 pm
haha yeh gota check it out first!
anyone else?
Volatile
Postby Volatile » Tue Apr 06, 2004 7:21 pm
TTT
Volatile
Postby matt dunn » Wed Apr 07, 2004 12:31 am
Mr Revhead wrote:go to your local toyota dealer. tell them you want a prepurchase inspection done. tell them to have a good look over it for an hour or so.
Yeah, a mechanic can check a lot of stuff in an hour and will check for mechanical condition whereas the AA will spend an hour noteing down the chips in the paint and the cigarette burns in the seat.
Postby Lanius » Wed Apr 07, 2004 8:36 am
Are you sure its MAP sensored? Most AE92's are AFM ... check and see if you've got a big bulky metal "thing" on the throttle body side of your airbox. If you've got one, then its AFM.
Lanius
Postby Monsterbishi » Wed Apr 07, 2004 10:28 am
Lanius wrote:Are you sure its MAP sensored? Most AE92's are AFM ... check and see if you've got a big bulky metal "thing" on the throttle body side of your airbox. If you've got one, then its AFM.
I don't know how true this statement may be, when we were sourcing the ECU's for our MR2 SC conversion, the only ones we were able to get were AE92 DLi MAP ecu's...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Shotgun » Wed Apr 07, 2004 11:15 am
I endorse Car Inspection Services. 309 8084. They do compression checks unless it's a freakin Subaru or something.
I was raised by a cup of coffee
Shotgun
Postby Lanius » Wed Apr 07, 2004 3:00 pm
I stand to be corrected of course ... :P
Mine is AFM ... 1989 Trueno GTZ
Lanius
Postby EVLGTZ » Wed Apr 07, 2004 3:13 pm
Most are AFM, but yes sum are MAP.
AFM was though to mid 1990, Map from then on but have seen the odd pre 90 with MAP and vice versa.
I'd be on the lookout for the MAP version as higher output mainly due to its slightly higher compression ration (8.9 vs 8.0)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Mr Revhead » Wed Apr 07, 2004 3:17 pm
to be exact afm is from 8705 to 8905
map is from 8905 to 9106
( 87 being year 05 month)
Postby EVLGTZ » Wed Apr 07, 2004 3:25 pm
Mr Revhead wrote:to be exact afm is from 8705 to 8905
Cheers warwick.
And those other misfits we come across are most likely to be the result of engine transplants?
EVLGTZ
EVLGTZ
Postby Mr Revhead » Wed Apr 07, 2004 3:38 pm
transplants, afm-map conversions. it is possible that the odd one snuck out after the change over, i mean if they had 500 afm engines left over they would use those up.....
but the other thing to remeber is where are you getting your vehicle date from? a 1st registered date is not the same as a build date, if the vehicle is made then sits around for a while before being registered it can appear to be say a 90 when it was in fact made in 89.....
also mistakes can happen when rego details are being typed in.
Postby IH8TEC » Wed Apr 07, 2004 5:52 pm
how do you find the build date of the car?
Postby yep11s » Thu Apr 08, 2004 1:10 am
So the AFM version would be better when turbocharging and Aftermarket ECU ?
yep11s
Postby IH8TEC » Thu Apr 08, 2004 1:26 am
doesn't matter if you get afm or map if your going aftermarket ecu, because you'll be able to tune it properly.
but if turbocharging with aftermarket ecu, map would be better, i think a afm has a limit on the airflow to a point, dont quote me on that, whereas you could get as much air in there as you like with a map, and just tune for the extra fuel you'll need etc.
just go for the map sensor one, better for higher output engines, be better in the long run.
Postby Mr Revhead » Thu Apr 08, 2004 10:10 am
to find the build date you need to go see ya local toyota dealer with you FULL model and frame numbers. with that they can tell you
Users browsing this forum: Bing [Bot] and 66 guests
