16v 4age issues. white/blue smoke
Postby Pies » Thu Apr 08, 2004 1:38 pm
ok, so a few weeks back my AW11 started smoking like a mofo. its white smoke, little bit of blue in it. smells oily, loss of coolant and oil. etc... so i figure its blown a head gasket
so a few weeks later (today) i finally get the head off to find that the head gasket is still in very good condition. theres quite a bit of oil around piston 1 on the gasket tho but im guessin that has just leaked out of the head.
what else could be wrong if its not the head gasket?
Current Rides:
Pies
Postby PumpN » Thu Apr 08, 2004 1:51 pm
rings most likely, they tend to go when the car is thrashed and/or old
lose of coolant could be from a leaky waterpipes, radiator, waterpump, thermostat around the gaskets, best way to know that its not the head gasket is to get a garage to check the cooling system for hydrocarbons, another easier way to check is for frothy shit everywhere
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby Ae92typeX » Thu Apr 08, 2004 1:52 pm
Possibility that the oil ring is stuffed on #1.
I had a car which had mint compression but the oil rings were gone causing the oil to puff rite throu!
failing that, what about valve seals?
Ae92typeX
Postby Pies » Thu Apr 08, 2004 1:53 pm
we ran a pressure test on the cooling system and it was leaking somewhere. not sure where tho.
could be the valve seals i guess? but i think they were replaced not long before i got it
Current Rides:
Pies
Postby Leon » Thu Apr 08, 2004 2:35 pm
Have you crack tested the head?
