Boot leaks on 86 FX-GT
Postby Serkix » Sun Apr 04, 2004 12:53 pm
And it's really starting to piss me off, I can't quite work out what it is. Is this a common accurance? I don't want a bloody pond in my boot. :evil:
lol thanks for any help
Serkix
Postby ChaosAD » Sun Apr 04, 2004 3:02 pm
If you pull the boot seal off you will probably find a shitload of rust.
ChaosAD
Postby Serkix » Mon Apr 05, 2004 9:15 pm
Yep....Yeah the metal rim thingy is all rusted....
I suppose that is the cause? :cry:
Serkix
Postby badassmofo » Mon Apr 05, 2004 11:14 pm
run a hose over ya boot to find the leaks
check your tailights as well!
Yes.
badassmofo
Postby Rollin' » Tue Apr 06, 2004 10:12 pm
yeah, first thing ya do when u get an AE82-fix the rust&leaks!!
boot- above the "FX" there should be a hole to fix, and take the rubber strip off that goes around the whole boot, fix rust, paint up and apply GREASE on it before u put it back on, this keeps the water off from fusting further and keeps it water tight.
and it the boots rusting, fix the tyre well while your their, and your front firewall on the inside may be rusting aswell, this is a litte more tricky to fix.
AE82 16.4 @136kph
ex:AE80 dx sedan, the green machine
corrola's are for life:
not just for christmas!
http://toyspeed.blakjak.net/profiles/profile.php?id=166
Rollin'
Postby Serkix » Fri Apr 09, 2004 4:54 pm
Yeah there's a bit of rust above the "FX". Just below to rubber seal around the back windscreen. So it's the that problem? Do I need to get the back windscreen resealed? or something. Cost?
Thanks for your help mate.
Serkix
Postby ChaosAD » Fri Apr 09, 2004 6:27 pm
Also check your "a pillars", below where your accelerator foot sits (and the same place on the passanger side), below the tail lights etc
ChaosAD
Postby Rollin' » Sat Apr 10, 2004 6:59 pm
there is no re-sealing to do as the rear windo "pops" outr, its just encased with the rubber you can see. all u nee to do once the window is out is to grind back the rust till itas gone, then apply rust converter/primer to it, then put on some polyester filla (aka bog) then either paint the whole boot or touch it up, i welded a small plate on mine then boged over that, and resprayed teh whole boot, no cost for me as my stepfather did all the work while i was away.
yeah as caos ad saitr, the a-pillar goes as well top and bottom.
AE82 16.4 @136kph
Rollin'
leaky boot
Postby fxgt race » Sat Apr 10, 2004 10:50 pm
try also taking the rear lights out and pop out the plastic holders that hold the lights at the bottom ,try sealing these as they always leaked on my fx
fxgt race
