Buzzing MR2
Buzzing MR2
Postby FST4RD » Fri Apr 16, 2004 4:46 pm
Not sure if this is normal, but when my mr2 is turned off, every so oftern out of the engine bay you can hear a buzzing noise, it comes from the passenger side if the car, does anyone else get this noise, is it normal??
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Mr Revhead » Fri Apr 16, 2004 4:55 pm
yes it is normal for injected cars.
i cant remember what it is but its something to do with the emissions side of things i thk
Postby MR2boy » Fri Apr 16, 2004 5:04 pm
its the charcole? purge canister, some sort of purge canister anyway but yes its normal
MR2boy
Re: Buzzing MR2
Postby MrBob » Fri Apr 16, 2004 5:13 pm
FST4RD wrote:Not sure if this is normal, but when my mr2 is turned off, every so oftern out of the engine bay you can hear a buzzing noise, it comes from the passenger side if the car, does anyone else get this noise, is it normal??
tis normal, pop your engine cover and locate the black purge canister (size of a coke can...or there abouts), mounted against strut tower on passenger side. Have a couple of vacume lines in the top. if you remove them it should stop "buzzing" . if you suck on one it should buzz. I think its just a worn reid-type valve which makes noise when vacume is applied.
MrBob
Postby FST4RD » Fri Apr 16, 2004 6:47 pm
Thanks for that thought it was something dodgy!!!!
FST4RD
Postby Snoop » Fri Apr 16, 2004 7:01 pm
8O 8O hahahhaa I thought my battery was shorting inside itself or somthing :lol: :lol: wat a relief :)
A plan so good my head would explode if I even began to know what I was talking about...
Snoop
Postby M R 2 Mk1 » Fri Apr 16, 2004 8:13 pm
Ive always wondered too :lol:
Working Sucks and Thinking is for Losers
M R 2 Mk1
Users browsing this forum: Google [Bot] and 27 guests
