Car turns off, Water leaking from engine ae101 gtz
Postby Banga69 » Fri Apr 23, 2004 10:36 am
Well i filled my radiator up yesterday morning bout 8:30, when i finished work yesterday and drove home bout 5:30 my car turned itself off i waited and to see what was wrong then water started leaking somewhere in my engine its on the side where the cam belt is, and i know its not the radiator.
if it helps when i turn my heating setting to (off) heat/cold still comes out into the cabin.
clint
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby aesc » Fri Apr 23, 2004 10:41 am
Sounds like water pump dude. its not a biggie they arent actually all that expensive to replace just had mine done cost like $40 for the part new through contacts
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Banga69 » Fri Apr 23, 2004 10:44 am
aesc wrote:Sounds like water pump dude. its not a biggie they arent actually all that expensive to replace just had mine done cost like $40 for the part new through contacts
yea its pretty bad the waters leakinginto my pulleys and onto my belts hope its not getting into the s/charger, and its makinf a funny noise too.
whats the retail on one of those?
how much to fit them?
is it ok to drive it?
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby Mr Revhead » Fri Apr 23, 2004 11:34 am
$40 for a new genuine waterpump? only if you stole it....
i can do new geuine water pump for $104 inc freight and gst
Postby aesc » Fri Apr 23, 2004 11:36 am
Na it wasnt genuine
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Fri Apr 23, 2004 11:39 am
ok, so you didnt steal it then! :D
Postby Banga69 » Fri Apr 23, 2004 12:02 pm
Mr Revhead wrote:$40 for a new genuine waterpump? only if you stole it....
just called up king toyota in the lower hutt and they said i get score one for around $120+ gst.
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby Mr Revhead » Fri Apr 23, 2004 12:04 pm
yep thats the normal retail price. but as a toyspeeder i give you a discount
Postby Banga69 » Fri Apr 23, 2004 12:11 pm
Mr Revhead wrote:yep thats the normal retail price. but as a toyspeeder i give you a discount
sounds good, buti kinda need it by minday.
is it ok to drive with water leaking from my water pump?
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby Mr Revhead » Fri Apr 23, 2004 12:13 pm
ok im afriad the earliest i can do is tuesday!
just make sure you stop every now and then to top it up! also be aware that if the rotor in the pump fails it wont be pumping water so it will very quickly overheat
Postby Banga69 » Fri Apr 23, 2004 12:16 pm
Mr Revhead wrote:ok im afriad the earliest i can do is tuesday!
ive got 2 2litre bottles of water in my car ready for it :twisted: its ok at the mo just staying on half way.
arr stink kinda thing i need asap.
CURRENT:
1994 Mazda Lantis
EX:
Banga69
