t50 to w55 cross member
Postby slonlo » Mon Apr 26, 2004 12:12 am
is there a cross member that bolts in or one thats easy to adapt
'89 LiteACE van
slonlo
Postby KinLoud » Mon Apr 26, 2004 8:14 am
What car is the question about? Some cars came with either a t50 or a w55 depending on the engine fitted (AA63, TA63 Carina).
Does it have a T50 and you want to swap to a w55?
Do you have a T50 crossmember and want to bolt a w55 to it?
With a bit more info I might be able to help you.
Ken
Taupo
021 408 863
Postby slonlo » Mon Apr 26, 2004 11:20 am
ok its for a ta23
used to have a t50
now have a w55 to put in
need to sort out a crossmember for the gear box
looks like the t50 mount is about 2 inches to far forward
'89 LiteACE van
slonlo
perhaps
Postby Ganjasaur » Mon Apr 26, 2004 12:48 pm
Well Im not too sure but you could no doubt use a w50 xmember from a ra23 or ra28. If not im sure www.toymods.org.au will have something in the forum about the conversion.
Ganjasaur
Users browsing this forum: No registered users and 61 guests
