Trans change
Trans change
Postby BULLET » Thu May 06, 2004 9:22 pm
hey guys my car is a pussy az auto and i want to change it to a manuel
seriously my auto is stuffed can someone tell me what to do and what i need all comments will be helpful hopefully oh yes my car is the 88 corona.
Current ride:
1988 Toyota Corona
BULLET
Postby craufurd » Thu May 06, 2004 9:29 pm
if its front wheel drive dont even bother.
craufurd
Postby BULLET » Thu May 06, 2004 9:42 pm
bugger!! what about an engine transplant will help or is it best to sell it.
Current ride:
1988 Toyota Corona
BULLET
Postby craufurd » Thu May 06, 2004 9:50 pm
well the only reason is that front wheel drives are annoying to work on. you can probably pick up a replacement gearbox really easily at pick a part tho, theres always heaps of those fwd coronas there, then you would need a pedal box with clutch and a hdraulic clutch master/slave and the fittings for the gearstick - pushrods etc and the gearstick surround that has all the mountings for the manual gearstick - you could get all this stuff fror probably 150ish i guess maybe 200 hundred at pick's. but you'll have to drill holes in you firewall for the clutch and also for the pusrod things too most likely, would be quite a lot of work for an old fwd
craufurd
Postby Ae92typeX » Thu May 06, 2004 9:56 pm
The car should have all the holes there ready. My supra's auto going manual and all the mounts & holes are there- generally car bodies are made ready to accept manual or auto (generally!). Like said you will need all the pedal box etc etc. I'd say go pick a part too- they have soooo many coronas usually. If you didnt want to go the wrecker route then I'd probably look at just swapping cars if I were you.
Ae92typeX
Postby BULLET » Thu May 06, 2004 10:05 pm
I agree goin to pick a part there's so many corona's in there its not funny
but thanks for the help guyz.
Current ride:
1988 Toyota Corona
BULLET
Users browsing this forum: Bing [Bot] and 17 guests
