Damo Monster wrote:i have a worry that my afm isnt working os well on my '92 ae101 levin... can anyone tell me if there is a test or something you can do to be sure? there arent any error codes lighting up in my dash...
cheers,
damo
well, i was thinking it might eb running rich or something cause it tends to stink of gas a bit, and smokes a bit too from what im told (although ive never seen it... mind you thouhg, its pretty hard to see smoke when your driving the car... and it doesnt do it at idle, and it doesnt use oil..) and then someone said to me that my afm could be a bit tired... so i thought id ask...
GEOFF wrote:I take it your running a silvertop 20v? They tend to smoke a bit under hight revs due to over fueling.. this is done to keep the cylinders cool because of the high compression ratio.
(i think)
GEOFF wrote:realy? based on what?
aesc wrote:I thought that the o2 sensor doesnt effect A/F mixture (or black smoke if rich) during wide open throttle (WOT). its more likely to be something else, like leaking injectors, excessive fuel pump pressure, ruptured fuel pressure regulator diaphragm, faulty PCV valve etc. Correct me if im wrong
