MR2 Intercooler Tech - Shrouded fan, when do you want it on?
Postby Wildcard » Thu May 13, 2004 10:58 pm
One of my new purchases is a Spearco 'hybrid' sidemount IC for the MR2. Surprisingly the kit comes with a boost switched relay intended to turn the fan on above 5psi. Attached is the photo of the IC which you can see is shrouded against heat from the engine bay with only the fan opening allowing air movement. The fan is off in the picture. This shrouding would appear to be good at stopping heatsoak at low speeds but I imagine at higher speeds would present a flow problem.
Anyway....
My question is simply - what are your opinions on retaining this setup? The other option is to tap into the engine bay temp sensor used to activate the stock fan, this seems the more efficient approach to me - to stop heatsoak when it occurs rather than just fighting the temps when your on boost.
Wildcard
Toyspeed Founder
Postby KiwiMR2 » Thu May 13, 2004 11:18 pm
Intresting....I have a Greddy one on the way from Japan, have been looking into fans & shrouds for a while as well. Either way I'd be intrested to find out how you get on.......I would have thought it would have been easiest to tap the new fan into the same system as the factory one??
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Wildcard » Thu May 13, 2004 11:37 pm
Agreed, thats why I'm wondering if there are some advantages to the boost activated approach since it would have cost more to include than just providing instructions to tap into the stock system.
Wildcard
Toyspeed Founder
Postby KiwiMR2 » Thu May 13, 2004 11:39 pm
Indeed.....calling Fivebob or Nemesis ;)
You have 1 fan?? whats the general opinion on one pusher one puller??
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Al » Thu May 13, 2004 11:52 pm
Hang on....doesnt the Spearco fan draw air through the ic into the engine bay?
Al
Postby KiwiMR2 » Thu May 13, 2004 11:54 pm
Al wrote:Hang on....doesnt the Spearco fan draw air through the ic into the engine bay?
Yep....why?
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby anthonym » Fri May 14, 2004 12:05 pm
Based on my experience, switching the fan on and off according to boost would be pointless. If you care, switch it based on a temperature probe in the intercooler inlet, otherwise leave it running all the time.
anthonym
Postby Wildcard » Fri May 14, 2004 12:13 pm
Which begs the question, whats the life expectancy of a decent fan?
[This is an 8" 'Turbo' SPAL fan].
Thanks
Wildcard
Toyspeed Founder
Postby dohca » Fri May 14, 2004 1:44 pm
depends, most computer fans "long life" have a 10,000hour MTF "mean time between failure"
so i would assume anywere between 5,000hours to 25,000 hours continued use
does it really need the fan?
dohca
Postby MrBob » Fri May 14, 2004 3:51 pm
dohca wrote:does it really need the fan?
most definately when stationary (ie, sitting in traffic). Ive found the temp is quite stable when moving, but starts to raise pretty quick when theres no flow through it. A decent fan drawing plenty of air through should help reduce this a bit. BTW I have the Apexi IC with no shroud
Just leave it on all the time. Ive been running the crap factory one continuously for a long time now and its still ticking (although shitty and ineffective)
MrBob
Postby mike86ze » Sat May 15, 2004 4:12 pm
how is the old ic setup? and the new?
didn't take the time to make a conclusion but think these might help
Fan-Forcing Your Intercooler, Part 1
http://www.autospeed.com/cms/article.html?&A=2121
Fan-Forcing Your Intercooler, Part 2
http://www.autospeed.com/cms/A_2153/article.html
also relevant...
Intelligent Intercooler Water Spray
http://www.autospeed.com/cms/article.html?&A=0527
mike86ze
