blacktop cams
blacktop cams
Postby qik20v » Thu May 13, 2004 5:09 pm
has anyone actually put cams into a blacktop?
if so what power gains did you notice and what duration/lift were they?
also anyone done this on a standard computer? or is it better to just get a link plus?
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby Blkwinter » Fri May 14, 2004 3:36 pm
^^im quite interested about this too. I'm thinking of putting some new cams in later on^^
Blkwinter
Postby MattrickMotorsport » Fri May 14, 2004 7:32 pm
I have
Answer Secret, Secret and just get a Link :wink:
MattrickMotorsport
Postby Sanxta » Sun May 16, 2004 5:34 pm
is it possible to put blacktop stock cams into a silvertop and would you want to?
Sanxta
Postby RedMist » Sun May 16, 2004 5:52 pm
Yes it is, intake is slightly longer in duration. It wouldn't make a great deal of difference.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Mon May 17, 2004 10:33 am
haha yeah seems that most ppl that are currently playing with cams in blacktops are doing it for racing/rallying... so hush hush!
try calling kelford camtech i no they have supplied some cam bits etc for a black top running cams and a motech... weather they will tell you anything though...... (dont think the cars been dynod yet)
Postby 10k 20v » Mon May 17, 2004 7:37 pm
any cam shop you talk to will tell you what grind they'll give
Main thing is this though. If it sounds to cheap it will be nasty.
10k 20v
Postby MattrickMotorsport » Mon May 17, 2004 7:39 pm
Not always Kelford will always be more expensive you just need to know who to talk to
My cam grind was just mild but will be going more aggresive one later on :wink:
MattrickMotorsport
Postby 10k 20v » Thu May 20, 2004 8:03 pm
Hey MattrickMotorsport, sounds like we're heading down the same path with our engines. Are you going to the bigger valves as well?
10k 20v
Postby MattrickMotorsport » Thu May 20, 2004 9:56 pm
10k 20v wrote:Hey MattrickMotorsport, sounds like we're heading down the same path with our engines. Are you going to the bigger valves as well?
Havent really decided on what we are going to do
Car needs to be able to stop and handle before i make it go any faster
MattrickMotorsport
Postby boyracer69 » Sun May 23, 2004 4:48 pm
I have also gone with the kelford cam grind, couldnt be arsed getting there new cams for 1g and then have to get a new computer. There mild grind is ment to give and 8-10% increase in hp and run with the standard ecu.
boyracer69
Postby B_giB » Sun May 23, 2004 11:55 pm
ive driven a BZR with different cams, unknown specs of them, it just landed from japan for a car yard, all i can say is it was bloody fast and sounded nice at idle, would have just been a semi mild spec i would say
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Users browsing this forum: Bing [Bot], Google [Bot] and 74 guests
