Supercharger using oil
Postby Andy from the block » Mon May 17, 2004 3:09 am
Ive got a AE101 GTZ that is using up S/C oil.
I filled it up and within a tank of gas the dipstick reads low/near empty again.
I also lost a little boost when the oil runs low aswell, when oil was full I got close to 9psi when oil is low I get close to 8psi.
What could be wrong and what can be done to fix it?
cheers.
Andy from the block
Postby FLAWLES » Mon May 17, 2004 7:01 pm
is the sc making any funny noises
take the intercooler off and check if there is any oil in there u might have a pooed seal or pulley bearing fix this now if you do find that it is these prob it will cost you a crap load trust me been there done that :wink:
FLAWLES
Postby liftback » Mon May 17, 2004 8:43 pm
Ditch the supercharger, and whack a turbo on. There goes your oil usage usage problem, and you get a few more horse in return ;)
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
Whats all this then?
liftback
Postby Andy from the block » Mon May 17, 2004 10:11 pm
FLAWLES wrote:is the sc making any funny noises
Ive recently changed my pulley bearing so I dont think its that.
SC doesnt make any 'funny' noises other than the normal sound that other S/C cars Ive been in make.
The intercooler is clean, not really any oil or anything.
Andy from the block
Postby ~SlideWays~ » Tue May 18, 2004 1:24 am
who did you get to change your pulley bearing because i couldn't even find a supplier for the bearing and then was told by someone (on here cant remember who) that they werent made to be removed?
~SlideWays~
Postby FLAWLES » Tue May 18, 2004 6:49 pm
true the bearings " look like they can not be removed but the can be with a bit of mucking around its held in to by two plastic pins that you can pull out
FLAWLES
Postby Andy from the block » Tue May 18, 2004 9:51 pm
~SlideWays~ wrote:who did you get to change your pulley bearing because i couldn't even find a supplier for the bearing and then was told by someone (on here cant remember who) that they werent made to be removed?
I got Bazda to do it for me...he didnt have any problems.
He had a spare one from his AE92 GTZ cuz he went turbo.
..anyway back to my original topic...what should I do to fix my s/c using oil? what shod I check or look out for?
Andy from the block
Postby aesc » Tue May 18, 2004 10:12 pm
Its not leaking oil is it? Could be one of the seals
EX AE101 owner
2013 Ford Focus ST
aesc
Postby FLAWLES » Wed May 19, 2004 4:30 pm
WHAT the????????
i brought my sc of bazda
what gives??????
i hope my sc is not full of seconds
BAZDA!!!!!!!!!!!!!!!!!!!!!!! :evil:
FLAWLES
Postby Bazda » Wed May 19, 2004 6:55 pm
is everyone dumb...sorry
andy is talking about the tensioner pulley!!!!!!!
Andy everyone is talking about the bearing on the actualy supercharger :D
Postby FLAWLES » Thu May 20, 2004 6:39 pm
ummmmm yea my bad
but yea check the clutch or even cheek the belt tensoin
its always the stupid stuff
FLAWLES
Postby Andy from the block » Sat May 22, 2004 11:08 am
I just checked the intercooler and yeah it has little puddles of oil.. :(
How do I know what I need to replace?
Andy from the block
Postby FLAWLES » Sat May 22, 2004 11:19 am
nine times out of ten it would be oil just sillping past the bearing when hot but serously you mite have to take the sc off to cheak the play in the pulley bearing thats the most comin bearing to fail
its going to be a lot of messing around for piss all but hey its going to save you some cash
FLAWLES
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
