Ma70 supra info wanted
Postby FLAWLES » Thu May 20, 2004 6:45 pm
i do not no fudge about ma70 ma71 supras
i want to know more
does anyone know any good links for them??
i basicly want to know what options the car/engine/gearbox/diff/brakes & suspienson they came out with or the power out put from factory the weight etc
as im looking to buy one and turn it into the supra like on the cover of fast fours dec issue
any help would be wicked
FLAWLES
Postby z|gen » Thu May 20, 2004 6:49 pm
found this in my history box http://www.toyota-mods.org/ma70.html not sure if thats what your after or not ?
AE91 SUPERCHARGED COROLLA
z|gen
Postby FLAWLES » Thu May 20, 2004 6:55 pm
spot on man thanks
now has anyone brought one before
what type of things do i look out for??? ie rust were etc
FLAWLES
Postby Silent Knight » Thu May 20, 2004 7:30 pm
I think the best ppl to talk to about these is either MrOizo or Looonie as they hve the same type supras :wink:
Silent Knight
Postby MrOizo » Thu May 20, 2004 8:08 pm
if you wana know about a sooopra then go to this site
www.supraforums.om
US based but the shizzle!!!
MrOizo
Toyspeed Legend
Postby FLAWLES » Fri May 21, 2004 6:39 pm
dude it dont work
im no good at this whole typing in a web site thing
hey it took me frecking 4 mounth to find toy speed :lol:
FLAWLES
Postby Silent Knight » Fri May 21, 2004 6:46 pm
it's he spelt it .om instead of .com
Silent Knight
Postby scotts2hot » Sun May 23, 2004 12:57 am
Rust - look round the spare tyre and below the tail lights.
If you're looking at one the first thing to look for is bubbles in the radiator while its running and/or milky stuff in the oil filler cap. If it has either of those walk away or prepare to spend big $$$ unless you can repair a blow head gasket yourself.
scotts2hot
Postby deaf_rattle » Sun May 23, 2004 10:32 pm
join the mailing list at www.supras.org.nz
the ma70 comes with either a 3l n/a or 3/ single turbo engine.
both have 24 valves and have dohc.
they weigh about 1580 standard and power otuput for the 7mgte is roughly 230-260hp
if you have any specific questions, feel free to pm me
Postby FLAWLES » Wed May 26, 2004 6:36 pm
thanks guys
no whitch engine i under stand that one can come out with the 7mgte engine and the othe " i think " is a 1m-something i dont know
any help
FLAWLES
Postby the fallen303 » Thu May 27, 2004 7:53 pm
the *a70 supras came with a 1g-ge, 1g-gte, 7m-ge, 7m-gte, and a 1jz-gte
the turboed 7m-gte is about 230hp and the 1jz is about 280hp.
the 7m can factory run up to 300hp with no mods other than sorting the HG (as they have a problem from factory of blowing HGs due to bad torque levels from factory) and uping the boost. with an aftermarket turbo, and suitable boost control, the 7m can comfortably take 400hp.
the 1jz can run factory up to about 350-400hp with upped boost. any more than that, and you need to change the turbo's as they are not up to the extra power due to their small size. replace the turbo's, get past boost cut, and normal breathing mods, and 500hp is easy on stock internals. 1jz does not need internal work unless your trying to aim for over 700hp, and even then, not really that big a deal.
the 7m motors were available right through production of the *a70 supras, but the 1jz's were only available from 1990 till 1992.
true house of JZ
Stay true to the origin
the fallen303
Postby FLAWLES » Fri May 28, 2004 6:53 pm
so basicly the 1jz motor is the beter of the turbod engines
how prone are the clyinder heads to warping????
sorry just trying to figure the best buy
FLAWLES
