Arc welding exhaust??
Postby Ae92typeX » Wed May 19, 2004 10:28 pm
Ive got a lil job to do on the exhaust, but my gas gear has run out. Never welded exhaust with an arc- does it do an ok job (assuming ofcourse the welder can weld properly)
dosent need to be flash, just functional
cheer
Ae92typeX
Postby Stu- » Wed May 19, 2004 11:49 pm
Its ok but with thin side walls all you'll end up doing is blowing holes. Be very carefull when starting, possibly strike an arc on soimething else to clear of the flux before you start on your exhaust.
Project Thread
Stu-
Postby Ae92typeX » Thu May 20, 2004 7:16 am
sweet, cheers
Ae92typeX
Postby skoty » Fri May 21, 2004 12:24 am
And remember arc welders car only weld steel, no alloy, stainless steel etc. Starting off using low amps would be ideal on an exhaust also :wink:
skoty
Postby Grotty » Fri May 21, 2004 9:33 am
you can weld stainless with arc.... !!!
Grotty
Postby MR2boy » Fri May 21, 2004 10:30 am
u sure can my exhaust is arc welded, its pretty hard to do so i tacked it together and dad welded it, its not particularly pretty but it works
MR2boy
Postby dohca » Fri May 21, 2004 10:49 am
works ok long as ur not a butcher haha.
depends on the rods etc to id use thin rods low amps and you should be right
dohca
Postby skoty » Fri May 21, 2004 11:21 am
skoty wrote:And remember arc welders car only weld steel, no alloy, stainless steel etc.
Maybe I will rephrase this... :roll:
To do a proper job on stainless, preferably you wanna use a tig, arc is pretty tricky.
skoty
Postby Ae92typeX » Fri May 21, 2004 3:03 pm
Mint,
cheers for the input guys. Engine just liffted out of supra today so I wont need to do for afew weeks now, but I'll give it a go then.
I was assuming low amps and thin rod. Looks aint important for the bit Im doing so it should go sweet.
Ae92typeX
