no water in battery??
Postby B_giB » Sat May 22, 2004 10:48 pm
i was playin around with my car and thought i would check the fluid levels, and there was no water in the battery!! 8O
what causes that?
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Ae92typeX » Sat May 22, 2004 10:57 pm
unless youve rolled upside down and havent noticed?... :)
then possibly your alternator is overcharging and boiling the battery. It dosent still work does it?- was it like bone dry?
Ae92typeX
Postby B_giB » Sat May 22, 2004 10:59 pm
battery works all good, but i couldnt see any water at all, and it took a bit of water, not sure how much they hold
B_giB
Postby Ae92typeX » Sat May 22, 2004 11:02 pm
when filling you want to just cover the plates by around 1cm usually. some batterys have a plastic 'foot' which goes down from the breather to show the level to fill to. others are clear and have a level.
have you noticed any smells while driveing?- boiling batteries sometimes smell like rotorua
Ae92typeX
Postby Leon » Sun May 23, 2004 12:29 am
if it's an oldish battery, or you just haven't checked it in a while, don't panic.
If it's a newish battery, and you have checked it recently, then check as above mentioned that it isn't overcharging.
Postby bridgeport » Sun May 23, 2004 12:30 am
pretty natural top it up shell be rite
bridgeport
Postby B_giB » Sun May 23, 2004 2:56 pm
first time ive checked it since i had the car and the battery came with it, i will just keep an eye on it and see what happens.
cheers guys
B_giB
