TRDmod wrote:Ok, well, cos I will be putting the car off the road kinda, and using it predominatly to run the engine over and on the track, not drag racing circuit, which is very strenuous on the engine constant high revs etc, engine will run hot. So I need to know what my temps are so I can regulate my driving and adjust according to the temp, now tell me if this is right
“the oil temp is put on a prob that’s already in a st205 apprenlty according to one shop, and will read the temp of the engine, …is that right, I thought they place the actual measuring devic eon the sump to measure how hot the oil is…:S or am I wrong….maybe I am because this is the first time I have looked into this…
now I will also be getting a after market air oil cooler.
Once I install oil cooler, would I expect bwetter cooling for the engine itself?
So to say, if I took my car in the circuit with out after market air oil cooler….take the average temp of oil and water, and I put in the oil cooler, would the temps of the oil and water drop down in average due to the oil cooler??
Users browsing this forum: Bing [Bot] and 70 guests
