K50 gbox wiring
K50 gbox wiring
Postby coleman » Thu Jun 03, 2004 9:11 pm
i just put a new k50 in a few weeks ago, but the electrical points for the reverse lights got ripped out,
i tried soldering back on but when car got rolling - no luck
i still have the old box - where the connection is sweet - it looks like the whole piece can be unbolted, am i right? is it easy?
any help would be good
coleman
coleman
Postby Virtual Genocide » Fri Jun 04, 2004 12:48 pm
Yes the whole piece can be unscrewd but if the g/box is already mounted in the tunnel chances are you wont be able to loosen it off because its on the top side of the bell housing, as far as i can remember ne way? Same thing happend to me when i put a k50 in my starlet, but i just left it.
You dont 'need' reversing lights :wink:
hope it helps?
Phil
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby coleman » Fri Jun 04, 2004 3:13 pm
yeah, i have a dark drive way and need them sorta, will do my best to get it off,
but will i fail my warrant that i dont have?
coleman
Postby PumpN » Fri Jun 04, 2004 3:28 pm
TOYODA wrote:yeah, i have a dark drive way and need them sorta, will do my best to get it off,
nah, you dont need backing lights for a warrent
they do come in handy if you get out and about at night though, as you surely know
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby coleman » Fri Jun 04, 2004 3:43 pm
i might just keep my big f*ck off mag light in close reach to the drivers seat just in case, muwuhahah
coleman
Postby Stealer Of Souls » Fri Jun 04, 2004 7:25 pm
You could fit a little switch that the gear lever pushes against when put into reverse and have that trigger a relay that turns on reverse lights (or if you wanna go hard core a set of rear fog lamps...)
That's what I was thinking of doing, my reverse switch died on me... I think I burnt it out... Tee hee... 55W reverse bulbs... tee hee...
Only thing is you'd need to attach the switch to the gearbox... otherwise you can't guarentee connection all the time... something I never bothered to think about how to overcome... Still shouldn't be too hard...
'86 AE85.5 Levin
Stealer Of Souls
Postby coleman » Fri Jun 04, 2004 7:30 pm
Stealer Of Souls wrote:You could fit a little switch that the gear lever pushes against when put into reverse and have that trigger a relay that turns on reverse lights (or if you wanna go hard core a set of rear fog lamps...)
sounds easier to pull the gearbox out again and re fit the thingee, hahah
not worried if it not needed for warrant
coleman
