does no1 on this forum no how to check super charger oil?
Postby event2 » Wed Jun 09, 2004 11:10 pm
where is it i cant find it! its a 91 gtz turino
cant figure out how to check it?!?! i got the oil and suringe and hose.
event2
Postby aesc » Fri Jun 11, 2004 8:57 am
reach down the back of the engine between the firewall and intake manifold, its the yellow wingnut about half way down the block. youll have to unscrew it to get it out
EX AE101 owner
2013 Ford Focus ST
aesc
Postby event2 » Sun Jun 13, 2004 11:00 pm
cheers!!!!
event2
Postby event2 » Sun Jun 13, 2004 11:02 pm
cheers!!!!
event2
Postby KinLoud » Mon Jun 14, 2004 5:09 pm
S/C dipstick - Get a good torch! It will make this much easier!
- look down the back of the engine near the throttle body. It should be a little yellow handle that looks a bit like a wingnut (I have seen one that wasn't painted yellow though).
Unscrew the wingnut and pull the dipstick out. From the full mark to the low mark is 100ml. Push the tube well into the hole when you are filling it up - otherwise the oil can bubble out as you squeeze the syringe.
For more info do a search on this forum for s/c oil or snake oil (I'm not kidding)
If you have any probs give me a call.
Ken
Taupo
021 408 863
