tyre pressure for drags?
Postby IH8TEC » Tue Jun 08, 2004 9:56 am
was just thinking when i was reading the posts for the toy/hon drags, talking about gettign quicker times with less pressure in tyres,
reason i ask, is when i ran 14.78, i had 32psi in the tyres as i run on the street, how much faster could it be with just doing that, and what pressure do you guys think, my tyres are r14, 195/60 dunlop formula 901's
brendon
Postby Bazda » Tue Jun 08, 2004 10:09 am
on street tyres i dropped my pressures and it made it wasy slipprier.
On decent rubber I think it works by dropping the pressures so the tyres can crinkle.
I played around but found it made no difference when u dont have any traction at all to start off with :D
Postby strap-on » Tue Jun 08, 2004 4:34 pm
dropping the tyre pressure means the tyres will splt out more, so it wille ffectivly give you a bigger foot, and a wider traction area, but as with everything:
pros:
will increase traction off the line
cons:
will increase drag down the line,
you just gotta try trial and error untill u get what works, i dropped mine down to 22-23 psi, but dont drop them down too far otherwise the cars weight will force the tyres off the wheel wall.
and remember to chek ur pressure after each race, as the heat will caus ethe pressure to expand again
strap-on
Postby Rollin' » Wed Jun 09, 2004 2:53 pm
i had mine at 18 psi ohn the drag strip, and i kept letting abit it out over the night, combined with more practicek coldere air,my times got better.
AE82 16.4 @136kph
ex:AE80 dx sedan, the green machine
corrola's are for life:
not just for christmas!
http://toyspeed.blakjak.net/profiles/profile.php?id=166
Rollin'
Postby Loudtoy » Wed Jun 09, 2004 11:22 pm
It's all personal preferance for what you run tyre pressure wise - i can run anywhere between 18-26 psi on the strip and get roughly the same sort of 60 foot/half track times with a small difference in trap speed - depends on the state of the track cos if it's slippery to start with i get more with higher pressures but if it's nice and sticky i get away a whole lot better with lower pressures!
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby AXNGRL » Fri Jun 11, 2004 1:13 am
and if you let too much air out, be careful when you try to turn off the track at the end :D
AXNGRL
Postby strap-on » Fri Jun 11, 2004 2:03 am
or when u try drive into town to get air lol
strap-on
Postby Mr Revhead » Fri Jun 11, 2004 2:04 pm
dont go too low though! youll stuff the side walls, if your running low profiles then prob not a good idea to go much lower then you normally run.
also think of how the tyre foot print acts... the more pressure the more it 'bumps' out in the middle, the less pressure the more the sides will carry the load, what you want it the entire surface in contact withthe road.
but as stated above, trail nd error is the only way to find whats best for your car! but you wanna heaps in non driven wheels.
