FWD/LSD gearbox fluid?
Postby celica_tommo » Wed Jun 09, 2004 11:32 pm
just wanting to know what fluid I need for a front wheel drive lsd gearbox? It's an E-56
celica_tommo
Postby Jools » Thu Jun 10, 2004 1:23 am
Theres no "special" fluid, but you need a certin grade (which i dont know exactly)
I use Redline 70W80 Synthetic , nice n' smooth :)
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Re: FWD/LSD gearbox fluid?
Postby matt dunn » Thu Jun 10, 2004 8:12 pm
celica_tommo wrote:just wanting to know what fluid I need for a front wheel drive lsd gearbox? It's an E-56
Either LSD oil to protect the diff and wear out the syncro's
or
VMX or similar gearbox oil to wear out the diff and protect the syncro's.
And old problem that AFAIK has no real answer.
Postby 10k 20v » Thu Jun 10, 2004 8:24 pm
what type of lsd?
10k 20v
Postby celica_tommo » Thu Jun 10, 2004 9:19 pm
no idea actually... what type of lsd is yours jools?... mines the same
celica_tommo
Postby Jools » Fri Jun 11, 2004 2:53 pm
Should be tommo, dont know which type tho, more than likely viscous
But dont run LSD oil, as its designed for rear diff LSDs NOT gearboxes
90 Celica GTR Turbo
www.Jools.tk
Jools
Postby 10k 20v » Fri Jun 11, 2004 8:26 pm
if it's viscous you don't need lsd oil.
I run castrol syntrax ($90 per 4 litre pack 8O ) and i run torsen lsd.
Royal oil's have just brought out a transaxle lsd oil!!!
10k 20v
Postby Malcolm » Fri Jun 11, 2004 8:36 pm
From what I've heard you dont need to run any form of LSD oil in a TorSen diff as it relies on a clever series of gears to split torque, rather than clutch packs which require friction modifiers found in LSD oil
Postby 10k 20v » Fri Jun 11, 2004 8:47 pm
which is excatly the reason i run synthetic gl5 gear oil which is what the syntrax is and has no lsd property's
10k 20v
Postby celica_tommo » Fri Jun 11, 2004 10:11 pm
very confusing :? ... I think I'll just use Redline 70W80 Synthetic as well
celica_tommo
Postby Jools » Fri Jun 11, 2004 11:40 pm
celica_tommo wrote:very confusing :? ... I think I'll just use Redline 70W80 Synthetic as well
Redline is GL5 as well, costs roughly $25 a litre
90 Celica GTR Turbo
www.Jools.tk
Jools
Postby Malcolm » Sat Jun 12, 2004 12:29 am
I use Dextron III ATF in the 185 :)
Postby Mr Revhead » Mon Jun 14, 2004 11:42 am
true, but if its a stock toyota lsd then itll be viscous, not torsen/helical type
Postby vvega » Tue Jun 15, 2004 7:40 pm
some come out with a stock torsen if its optioned
viscous dont matter as they are a sealed unit
unlikely it will have a clutch type as stock but trd do make a retrofit one
syntax gl5 is a good oil
v
vvega
Postby NZ_AE86 » Tue Jun 15, 2004 10:21 pm
If you use ATF it will be fine whatever type of LSD you have. If you use a gear oil and do some how have a plate LSD you will stuff it and it will not work properly.
NZ_AE86
Postby Mr Revhead » Wed Jun 16, 2004 10:43 am
what models? i havent found any yet....
ae86 had clutch pack so did some chasers etc, ae92, 101 and 111s had viscous coupling as did jza80 supras mr2 etc etc
TRD do either helical (torsen) or clutch pack type. both for some models
Postby vvega » Wed Jun 16, 2004 8:25 pm
glanza v has the factory option
ae101 has the factory option
111 as well
gt4/s have a torsen in the rear as factory
supras have a torsen in the rear as stock as well
this info comes directly from toyotas own parts database
if you wish to argue it go talk to waikato toyota its there system i use
then tell uen to take out the factory torsen out of his 101
yes hes actually seen it out of the box so hes sure
i have been looking for a replacment for my mr2 diff and so have resurched this quite a lot
the viscous will not fit in the c52 or c56 due to its size hence the torsen
the gtz box is basically the same as the sw20 box so is viscous
v
vvega
Postby MrOizo » Wed Jun 16, 2004 8:40 pm
im sure the JZA80 manuals do and optional on autos - and iknow for sure my JZA70 has a torsen stock....
i was told to use half ATF and half LSD oil... may have been for shits anfd giggles but yeah :o
MrOizo
Toyspeed Legend
Postby blitza » Wed Jun 16, 2004 11:08 pm
put home halogen fluid in to it. :D
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby Mr Revhead » Thu Jun 17, 2004 11:23 am
ok first up i dont need to call anyone at waikato... i have the epc right here in front of me...
second, just to clarify that we are all talking about the same things here:
helical/torsen as done by TRD and quaife..... gear type lsd
clutch pack lsd... uses clutchs to limit slip
viscous........ uses fluid
when looking up the epc it doesnt tell you if its helical or viscous type, no way to tell that acuratly from the epc, it just shows a complete centre unit. some of which look more like vicous than not. you can tell if its got clutch pack as the shims are seperate parts. so i retract what i said about supras, never had one apart. for the 70series it shows both clutch pack or what could be either viscous or helical. in hindsight i would lean towards helical as they tend to be a better unit to use with heaps of power.
as for the 'e' series box i have never heard of or seen a factory fitted helical type. have done so with viscous though, that would also explain why the 'c' lsd boxes use normal gear fluid, the viscous is sealed and has its own fluid encased within. having said that though, i believe some helical units can also use normal fluid.
viscous are far more common as fwd diffs, they dont have the torque steer of other styles
if you pull apart a 'e' series and its got a helical type then chances are its an aftermarket one. congratulations.
if anyone can prove different id love to see the evidence... im here to learn as well :wink: [/quote]
