FWD/LSD gearbox fluid?
Postby vvega » Thu Jun 17, 2004 6:43 pm
ok ill say it again
vicous wont fit in a c52/56 the unit is to large
and ewan"10k20v" has a confermed torsen in his
your correct in saying a viscous is a weak lsd so give less touque issues
there sre very few torsens in the c seres g/boxes
imm still tring to find another
apprently the bzr box has one as stock
this is where ewans one came from
vvega
Postby 10k 20v » Thu Jun 17, 2004 7:01 pm
Mine is garanteed torsen, no trd markings or anything so i presume stock toyota item and i use normal gear, albeit expensive synthetic
And no, i'm not going to pull it out again for pics, shits and giggles,
And vvega edit you post dude, not viscous aye!!!
Ewan
10k 20v
Postby QikStarlie » Thu Jun 17, 2004 7:30 pm
yeh my trd torsen, helical whatever you want to call it diff had no markings. but yeh, who cares long as it spins both wheels
QikStarlie
Postby Mr Revhead » Fri Jun 18, 2004 10:21 am
oops, when i said 'c' series before i meant 'e' series :oops: .. have edited post
the ae101 'c' series box doesnt show an lsd option. the gtz uses the viscous type in the 'e' series box
the starlet turbos use the c56 box with viscous lsd.
the ae111 bzrs suposidly had lsd stock but we had one a month or so ago that wasnt.....
trans code for c160 6spd with lsd is c160-12c
Postby vvega » Fri Jun 18, 2004 1:40 pm
hehe
yeah if you look athe the caseings(on the epc) on the glanza v box you will see that the model with the viscous has a extended housing out the bac to acommodate the extra size of the viscous
just went down to k road and confumed that
will that c56 bolt up to a 4age?? or are they compleatly diffren tin the bellhousing ??
v
vvega
Postby Mr Revhead » Fri Jun 18, 2004 1:49 pm
yeah extended casing out the side as well...
to the best of my knowledge they will bolt up, later ae101s used the c56
and as with most other toyota boxes if you have an engine with a '#' type box another '#' type will fit.
Postby 10k 20v » Fri Jun 18, 2004 8:12 pm
ohh ohh, maybee mine is trd
10k 20v
Postby Mr Revhead » Sat Jun 19, 2004 10:08 am
thats my bet for the moment :D
Postby 10k 20v » Sat Jun 19, 2004 2:23 pm
hasn't been known for toyota if there adding an option to a new vehicle to source parts already manufactered, thus fitting trd diffs as stock items. just a thought
10k 20v
