fivebob wrote:From looking at the wiring diagrams it appears that you can't piggyback any of the temp sensors unless you connect them to an AV input (not a temp input which has a pullup to 5v), everything else should be ok though.
nemesis wrote:You are right, disconnecting the coolant temp sensor from the MoTeC solves the problem, looks like I'll have to dupilcate all the temp sensors.
krad wrote:If you have some electrical skills you could probably buffer the sensor that is causing you problems with a simple opamp follower circuit.
eg: sensor -> to normal ECU input.
-> opamp circuit (gain of 1) -> motech.
The opamp would effectively isolate it from the motech's 5V pull up.
This way you could just use the one sensor.
fivebob wrote:nemesis wrote:You are right, disconnecting the coolant temp sensor from the MoTeC solves the problem, looks like I'll have to dupilcate all the temp sensors.
Or upgrade to the M400 and use the AV inputs which can be assigned to ET/AT unlike the M48 which has fixed assignments
fivebob wrote:That is why you should be able to use the Aux Voltage pins on the Motec and get the correct value to both ECUs as only one is providing the 5v source, of course this relys on the stock ECU having a 1k Ohm resistor, or else you need to recalibrate the Motec (not very hard to do).
nemesis wrote:The ET sensor does need to be custom calibrated, how do you do this easily?
MartinNZ wrote:Nemesis...
Just wondered, why are you doing this? Why not just let the Motec completely control the engine? Are you just using it for datalogging?
If you can point me at the wiring info somewhere on the web I can try suss it out for you. I work as an electronic design engineer.
Martin.
fivebob wrote:You'll need a reference source for the ET so you know what the temp is, then it's simply a matter of connecting the Motec and the A/D value will be displayed, then enter that value in the appropriate cell. Other than that you'll need the resistance curve of the sensor and a least one voltage reading at a known temperature to calculate the A/D values.
nemesis wrote:This is not fun at all as the A/D values are not displayed for this configuration, but I've managed a crude calibration so far by matching the sensor voltage to a standalone temperature gauge with a probe stuffed down the filler neck, followed by on the fly adjustments.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 9 guests
