sergei wrote:In my opinion spark plugs make no big difference as long as they work, althou there are different types of sparkplugs (iridium and platinums are generally hot plugs - they last longer but can create detonation)...
Twolitre wrote:Unless you have a Mitsi V6, Subaru Boxer or equally painfull engine to change spark plugs in then just run normal steel plugs, they're dirt cheap and do actually produce more power than platinum plugs, they just don't last as long, although in a high performance turbocharged engine iridiums may be of some benefit, I'm not sure.
I'm with you Sergei, I'd like to hear if someone thinks that some spark plugs are better than other functioning ones
ROBODISCO_20v wrote:Dont listern to this guy he dosen't know what he's talking about.
ROBODISCO_20v wrote:I have but a set of NGK iridiums in my blk top 20v & it loves them, revs more freely over the std spec platnums.
fangsport wrote:when people say they had bigs gains etc from fitting iridium/platinum etc plugs, would they have got the same gains by fitting new replacement units , because the plugs that were removed were tired.
