AE92 toyota levin redtop what kind of mods can be done to this to make it alittle gruntyer it has TVIS also whats the standard power/ kw of this engine?
any help will help
last time i checked all engine's had steel rod's and solid cranks. Athe only difference between a bluetop and Redtop T-VIS engine is the red top has a 7 rib block and 42mm Big end's instead of the Blue tops 40mm. It kust make's them heavier then the blue top and not not as rev happy.redtop motors have the solid crank and also has the steal rods witch is like wicked so this means u can rev the f**kin nuts off it but the week point on these motors r the conrod bolts theu have a tenancy to break causein a biiig prob so if u do want to rev it hard replace these wif arp bolts
the bluetop has solid crank and alaloy rods
Users browsing this forum: Bing [Bot] and 67 guests
