but do i need to change the gearbox?
what parts in the car do i need changing when doing a engine+turbo conversion?
is ae85 and 86's suspension different?
what are different between the two, apart from the lsd gear box and the 3age and 4age engine?
93Levin4AGZE wrote:i will put in a 4agze block, with T3 turbo (ballbearing turbine), and all the other turbo setups.(of course the GTZ ecu)
badidas wrote:is ae85 and 86's suspension different?
ae85 will probably have drum brakes on the rear and 86 will have disk
and the frount on an ae86 is vented but the ones on 85"s are probably notwhat are different between the two, apart from the lsd gear box and the 3age and 4age engine?
the car isnt fwd the lsd would be in a diff not in the gearbox
and the engine is a 3a no such thing as a 3age
according to club 4ag the ae85 should have a t50 gearbox
if thats tru then you can bolt up a 4agze to it but it wont last long
but im sure they run a k50
according to club 4age also the t50 is good for 200 hp
and a w55 is good for 300 hp +
hope that helps
PumpN wrote:There are no lsd's for the AE85 k-series diff afaik, that and the K-series diff is weak as sh*t
PumpN wrote:[quote=
AE85 use K50 gearbox, it is weak as sh*t, as has been said go talk to nite_b and get a supra box which will cost a bit of coin but its cheaper then breaking precious T50's all the time.
There are no lsd's for the AE85 k-series diff afaik, that and the K-series diff is weak as sh*t and you dont want that drum rear end, get either an 28X AE86 rear end with disc's and an lsd if you can, not all 86 are lsd and its hard to find a diff which is, 283 and 285 rear end are factory lsd and 282 is open diffed but they can all have aftermarket lsd centres installed, either that or a customised hilux diff (<-- really good option if you can afford it), you will also need to upgrade the front brakes
really what you want to do is take the car off the road, and strip it and rebuild it from the ground up, there is a lot of work involved in doing it properly and its going to take coin and commitment but the end result should speak for itself
Drifter4ag wrote:I dissagree with TRD LSD / AE86 diff handling the power ..
i had Early TRD LSD in my first turbo ae86 which was around 230hp that one broke axles crown and pinions .. the LSD unit is strong but the rest of the diff is crap for power. You can get TRD center for G series diff which is fine even a shimmed diff in my opinion was just as good as the TRD diff which incidentally i had rebuilt
ae-86_lad wrote:i got hilux open diff![]()
i also read somewhere that some late model ae85 got a lsd.. mm.. probaly wrong.. i wouldnt bother with doing the ae85 up.. waste of time. get a cheap bad bodied 86.. who cares about rust.. and then just turbo the blue top.. and then get some shares in toyota engine company like drifter4ag does.. he got good return on those
Drifter4ag wrote:what is a good 7inch diff ? E series ? as far as i can see the G series is the best option if you have a turbo on any ae86 as LSD heads can be found bada bing and new TRD units are still available. F series LSD head is very very hard to find .. probably harder than second hand T series and TRD and other manufacturers have discontinued production of this one.
For 100% predictability .....get a locker
