Dash backlight disconnected (oops)
Postby eddiewould » Tue Jun 29, 2004 1:01 am
Hey when installing my headunit today I somehow managed to disconnect the dash backlight (the one for the speedo etc that goes on with parklights).
The car is a 1994 Celica... does anyone know what I've unplugged, and where I need to plug it back in?
I guess its possible I've blown a fuse as well... should check that.
Eddie
eddiewould
Postby Ae92typeX » Tue Jun 29, 2004 8:56 am
Check your fuses cos Ive seen on many occasions people connecting the headunit negative to the lamp wire (as with power off a multimeter reads it as negative). The headunit works fine, but when you turn on the lights the dash fuse blows. The head unit still works so it can be a little puzzling at first.
Ae92typeX
Postby eddiewould » Tue Jun 29, 2004 1:03 pm
Well there was a fuse blown, but I replaced it but the problem is still there :S
eddiewould
Postby eddiewould » Tue Jun 29, 2004 1:19 pm
On closer inspection the same fuse blew again when I turned on the lights.
Perhaps I have wired up my headunit wrong?
From the factory wiring harness, I've got :
Yellow = constant 12V+
Red = Switched 12V+
now heres the tricky part, I'm using an orange wire :S as my ground.
Orange isn't normally ground... but its the only wire I could get a 12V difference with.
Originally I thought it was the blue one - there was 12V across yellow/blue and red/blue... but when I actually plugged the headunit in, the voltage dropped to about 5V... so I don't think that was the right one.
But coming out of the factory wiring harness there wen't any other colours really! I guess I can tap a ground off the cigerette lighter?
eddiewould
Postby eddiewould » Tue Jun 29, 2004 1:20 pm
The headunit I'm replacing just grounded through the metal frame.
eddiewould
Postby Ae92typeX » Tue Jun 29, 2004 1:27 pm
just ground it to the nearest bolt/screw and try that.
Ae92typeX
Postby eddiewould » Tue Jun 29, 2004 1:55 pm
Yeah, you were right actually... a mate explained it to me at work :)
obviously my headunit is grounding through the screws at the moment so thats why its still working... and that orange wire I shouldn't be using is the illumination wire... so that the headunit 'glows' when the lights are turned on.
I'll tap a ground off somewhere else and I should be sweet.
Thanks for the help!
eddiewould
