Oil cooler sandwich plate – where do I get one
Postby TRDmod » Mon Jul 05, 2004 10:11 am
Ok, I went to enquire about an oil cooler, I got told I needed certain things, I found all of them no problems, but a bloody sandwich plate, no one sells them, does anyone know ehre I could get a sandwich plate or get one fabricated?
Whats cheaper, trd sandwich plate which I hope they have or get one custom made?
Feedback and advise would be great
Thanks
Have you got the hots? for what's in the box with the dots? ..... 0800 30 40 50
Domino's Pizza.....
TRDmod
Postby MrBob » Mon Jul 05, 2004 11:42 am
greenlane speed shop sells them (not TRD tho). Think theyre under GSS in the phone book
MrBob
Postby Mr Revhead » Mon Jul 05, 2004 3:57 pm
what engine do you have? if youv got a 4age you could use a aw11 one.
Postby fivebob » Mon Jul 05, 2004 4:26 pm
Mr Revhead wrote:what engine do you have? if youv got a 4age you could use a aw11 one.
He has the 3S-GTE, but they share the same oil filter as the 4A-GZE so the plate should fit.
The only question I would have is does it have a thermostat, or is TRDMod fitting an external one. IMHO Thermostats are a requirement in NZ, especially in winter, even in summer the oil takes 10-15kms to warm up on a stock engine. At best without a thermostat the engine will not perform up to it's potential, at worst it will damage the engine.
well
Postby TRDmod » Mon Jul 05, 2004 4:43 pm
wait a minute
why is that
because the oil would be too thick and cold??
i run 5w-50 100% synthetic oil on it, also, what if I cover the oil cooler when im not using it for circuit, that would have the same effect as having a thermostat wouldn’t it, I mean if you cover your cooler, then obviously it wont hav its cooling capability anymore
I have spoken to people with cars not for circuit just street and use aftermarket oil coolers to keep the oil temp down, and no adverse effects has been done to the car at all
(im not trying to trash what your saying, im tryignt o figure out the best ways about this, so don’t get me wrong)
Domino's Pizza.....
TRDmod
Postby Mr Revhead » Mon Jul 05, 2004 4:47 pm
yeah it could fit... but im gunna sit on the fence on that one... not had much to do with 3sgte (other than wiping the oil off their bums!)
on the aw11 they circulate the oil through a water pipe.
doesnt have a thermostat but i think running it through the water pipe would aid warmup then help cool it.
Postby Mr Revhead » Mon Jul 05, 2004 4:49 pm
running an oil cooler of the radiator type would increase the warm up time of the engine, IF it warmed up at all.
sure
Postby TRDmod » Mon Jul 05, 2004 4:50 pm
The gt4 205 engine has a water cooled oil cooler, but when circuit application and higher boost is applied, im afraid that isn’t sufficient, hence the cooler, if I cover it that’s fine, it wont have the extreme cooling capability that it would have, even covering it half, if you ever had a gt4 205, the engine bay gets to hot after a drive, especially on the track my god, I went on the track and I could probably have cooked some roast in the engine bay
Domino's Pizza.....
TRDmod
Postby fivebob » Mon Jul 05, 2004 5:05 pm
Yes it is because the oil is too thick and cold, and even worse may not warm up at all, especially at high speed if the cooler gets good flow.
Don't believe me if you want but I'd suggest you go to tech books and buy the ...to win series by Carroll Smith, he goes into details about why it's stupid to run without a thermostat, can't remember if it's in "Prepare to Win" or "Engineer to Win".
i knwo what you mean
Postby TRDmod » Mon Jul 05, 2004 5:07 pm
Fair enough
But, like I said, if I covered the cooler, it’s a small object and easily covered.
If I covered, it would not cool the oil … like an intercooler would not work if you covered it, same as radiator…..
Does that make sence?
Domino's Pizza.....
TRDmod
Postby fivebob » Mon Jul 05, 2004 5:17 pm
why waste time covering it, the amount of covering depends on the temperature. Much easier to fit a thermostat and forget it. One less thing to worry about, and it's a bit hard to get out in the middle of a race to uncover/cover up your oil cooler.
true
Postby TRDmod » Mon Jul 05, 2004 5:23 pm
true true, but im talking about a budget way of doing it:)
i havent enquired how mucha thermostat costs, which i will tomorow because this was bought up
but like iw as saying though, in theory it works perfectly fine if your ok with covering and uncovering it
Domino's Pizza.....
TRDmod
Postby Mr Revhead » Mon Jul 05, 2004 5:25 pm
riding mechanic.......? :lol:
Re: true
Postby fivebob » Mon Jul 05, 2004 5:30 pm
TRDmod wrote:true true, but im talking about a budget way of doing it:)
Earls make a sandwich plate with built in thermostat, about $30-50 more than one without IIRC
cool
Postby TRDmod » Tue Jul 06, 2004 8:47 am
sure, thats cool
quite a few companies sell thermostats anwyays
ill sort it out, its not that expensive
Domino's Pizza.....
TRDmod
Postby NA Drifter » Sat Jul 10, 2004 6:40 am
I run a remote oil filter kit for my AE86 with FC3S RX7 oilcooler. Brought the remote filter kit at Pioneor (spelling) Auto Part or something. It cost around $150 I think... was a while ago. I asked for a Ford unit as they have the same srew tread... I found the info on the net and it works. If you want, I'll look around for the resit and get the parts number for you...
Keith
NA Drifter
cool
Postby TRDmod » Sat Jul 10, 2004 9:25 am
sweet as man if you can do that that would be great
:) cheeeeeeeaars
Domino's Pizza.....
TRDmod
Re:oil cooler adapter
Postby NA Drifter » Sat Jul 31, 2004 5:48 pm
TRDmod wrote:sweet as man if you can do that that would be great
:) cheeeeeeeaars
Hi there, yeh, sorry for getting back to you so late... I finnaly found the resit for mine. But I haven't got it with me as i'm at Uni now... Will PM you again once i got home and on the net.
I was trying to find the post but took me so long to find it.
..Keith..
Keith
NA Drifter
Postby NA Drifter » Mon Aug 02, 2004 1:55 am
ok, here it goes... got from Pioneer Autoparts in 2002.
I guess the part number is...
CP 15715. Remote Filter Relocation Kit 3/4-16.
$ 133.81 included gst.
Hope this help.
Keith
NA Drifter
