Adamal wrote:You've connected the battery, right?
skoty wrote:It does have spark as it turns over. I think the injectors arnt operating, someone told me if there is a bad earth to the injectors the car wont run either.
skoty wrote:Matt: You mean the ones on the part of the wiring harness that run past the intake manifold?
4AGTE wrote:Just under the fuel rail on the left hand side the earth's bolt to the manifold. Its a 10mm bolt for this and i have made that mestake befor and took a little to sus it If thats the reason but its easily missed when putting the wiring loom back in.
4AGTE wrote:wont even consider starting dude. Not even show a sign of it.
skoty wrote: to solve this problem there was a special ecu sensor that was busted which from what I've been told determines the air/fuel mixture.
ke70wagon20v wrote:skoty wrote: to solve this problem there was a special ecu sensor that was busted which from what I've been told determines the air/fuel mixture.
special sensor? could it just be a Map sensor??or ya afm??
