TWSTD wrote:ok - found 16 pin OBD2 connector under dash with 6 wires going into it. Are any of these TE1 and E1? If so, which pins? (Ive searched the i-net and cant find a thing). Or do you need some form of scanner to access the ECU error codes on OBD2 systems?
TWSTD wrote:its got some form of traction control system - is that the same as electronic throttle control? I dont know much about these vehicles as its not actually my own car.
Symptoms: Increased revolutions KHKH of thoroughly heated engine, "neznachitel'naya reaktsiya" engine to the pressing of the pedal of gas, the lamp of "Chyuechk Engine" it continues to burn with the brought engine. First of all were schitany the codes of self-diagnosis. Using "tekhnologiyu" Without Scan Tools: -), schitan the code of self-diagnosis (MIL-code) 89 (malfunction of the drive of the choke of "zaslonki" - ETCS malfunction). Malfunction is localized, but this information it is clearly insufficient. With the malfunction of this system there can be schitany the following codes of self-diagnosis (SAE and Manufacturer ** DTC):
DTC P0505: IDLE Control System Malfunction
DTC P1120: APPS Circuit Malfunction
DTC P1121: APPS Range Problem
DTC P1125: THROTTLE CONTROL MOTOR Circuit Malfunction
DTC P1126: ELECTROMAGNETIC CLUTCH Circuit Malfunction
DTC P1127: ETCS ACTUATOR POWER SOURCE Circuit Malfunction
DTC P1128: THROTTLE CONTROL MOTOR LOCK Malfunction
DTC P1129: ETCS Malfunction Scanner OBDII of "popolnil" information since with its aid there was schitan code DTC P1128. After checking of the drive of shutter appeared the wedging of the rotor of engine (consequence of the prolonged of "prostoya" machine). The essence of malfunction consisted in the fact that after ignition YESM it attempted (unsuccessfully) to conduct positioning shutter. Naturally shutter in this case was not moved and, as a result, did not change voltage on the sensor of its position (TPS) Therefore YESM correctly considered defective the transmission system of motion. The replacement of rear spin bearing completely removed the problems of automobile.
Users browsing this forum: Bing [Bot] and 49 guests
