ae82 to ae92 shocks
ae82 to ae92 shocks
Postby low_rider » Thu Jul 22, 2004 12:06 pm
would ae 82 fxgt shocks fit into an ae 92 fxgt?
rulk
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
http://toyspeed.blakjak.net/profiles/profile.php?id=336
low_rider
Postby TRD Man » Thu Jul 22, 2004 2:05 pm
Front - yes, Rear - no.
TRD Man
Postby low_rider » Fri Jul 23, 2004 4:21 pm
is there anything i could do to make them fit?
rulk
low_rider
Postby TRD Man » Fri Jul 23, 2004 4:32 pm
It's the spacing of the lower mounting holes on the rear shocks taht are different. People have been known to 'reposition' the top hole before today.
Whether this is strictly warrantable is questionable.
TRD Man
Postby low_rider » Fri Jul 23, 2004 4:43 pm
do you know the measurements on each shock like ae82 or ae92
rulk
low_rider
Postby low_rider » Sun Jul 25, 2004 12:15 am
does anyone have the measurments of either
the shocks are from center to center 74mm, hole size 12mm
does that sound like ae82 shocks
rulk
low_rider
Postby TRDWGN » Sun Jul 25, 2004 10:42 am
The 92 rear hole spacing is approx around 5~8mm closer together than 82's however i think there might be a height differential as the 82 shocks are shorter overall than 92's by 3 odd inches. I have put 101 coilovers in my 82 and need to have the rears shortened somewhat so you may need to wind them up a far bit to level out your 92
TRDWGN
Users browsing this forum: Majestic-12 [Bot] and 6 guests
