Kender wrote:A couple of questions
1) Does anyone know why most (if not all) of the pictures of turbo'd 4age engines on the net use the n/a intake manifold as opposed to the s/c or custom intake manifold?
2) What is the advantage of turboing the 4age as opposed to using a centrifugal supercharger?
kender
Mr Revhead wrote:ahh but he said centrifugal supercharger, which are far better than the 4agze type, a lot of the same things apply but a centrifugal one would be an interesting prospect if a suitable one could be found, their main advantage is a far less parsitic drag. they also eliminate the inlet manifold choice problem. and they can flow heaps! but as i said the challenge would be finding one of a suitable size, maybe vortech to something
mike simmonds wrote:, if its throttle response and toque ur after obviously the supercharger would be the better option, but if u want top end and higher horse power ud go for the turbo as they are more efficent at producing top end power,
Andy from the block wrote:mike simmonds wrote:, if its throttle response and toque ur after obviously the supercharger would be the better option, but if u want top end and higher horse power ud go for the turbo as they are more efficent at producing top end power,
If turbo are more efficient at producing top-end power , how come the fastest drag cars in the world (ie the 8000hp dragsters in US) use supercharged engines, not turbo ones?
Now I just have to figure out how to make a centrifugal s/c with some tin foil, chewing gum and a rubber chicken. Does anyone know Macgyver's phone number?
Andy from the block wrote:If turbo are more efficient at producing top-end power , how come the fastest drag cars in the world (ie the 8000hp dragsters in US) use supercharged engines, not turbo ones?
