got20v? wrote:best size exhaust for a 20v is the FACTORY 2 an 1/4 inch pipe, i think this DOES have something to do with backpressure,it is to ensure a consistent flow of gases out of teh engine, and stops them swirling.
got20v? wrote:but the point i its too complicated to talk about so from my understanding everything is refered to as backpressure, but as far as i understand the myth of adding in resonators or mufflers for backpressue is indeed just that a myth like you say, however there is a lot to be gained by having the rite sized pipe
im pretty sure the exit on the 20v's extractors is 2 and a 1/4 so i dont se eth point in going to a 2.5
a 2.25 going into a 2.5, will disrupt flow, which will fu*k up the awesome job that the headers are doing
trueno wrote:The whole 'backpressure' thing is about maintaining gas velocity so that you get some scavenging effect at the end of the exhaust stroke.
If you can empty a little more of the cylinder then it probably would be worth some pumping losses (backpressure) but if you just slap on a pipe you dont know what it's doing. To develop an engine you need to experiment and spend hours on the dyno, everything else is just guesswork and hearsay.
Users browsing this forum: No registered users and 26 guests
