kp6# steering rack length
Postby Mr Revhead » Thu Jul 22, 2004 3:33 pm
i customer of mine in ausie is after the length of the steering rack off a rwd starlet.
anyone got one lying around they can measure for me?
cheers :D
Postby kingcorolla » Tue Jul 27, 2004 2:58 pm
is that including tierods? balljoints etc? all the way to the knuckle?
1983 Carina AA63 4age
kingcorolla
Postby Mr Revhead » Tue Jul 27, 2004 3:40 pm
yup from end of tie rods thanks :D
Postby turbora28 » Tue Jul 27, 2004 5:16 pm
Howdy, i'm the annoying aussie wanting the measurements :)
If its not too much trouble, i'm after the measurement from inner tie rod to inner tie rod. Not really worried about the steering arm length etc.
Many thanks!
Joel
turbora28
Postby rxtoy » Wed Jul 28, 2004 1:59 pm
you thinking about redoing the rack and pinion steering joel?
i was interested in trying it for my TA23 (eventual 1uzfe plans) but after reading the thread off toymods i'm semi put off, i haven't got the skills to get into it and work out all the stuff to get rid of bump steer and all the other problems.
if there was something with the right width it would be a hell of a lot easier though wouldn't it? don't you have KP starlets over in Aussie?
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby wde_bdy » Wed Jul 28, 2004 2:33 pm
The poor deprived Aussies never got the RWD Starlets.
I had a look in my shed for you, but unfortunately I threw out my last starlet rack, using a TA63 rack in my car.
Callum,
wde_bdy
Postby turbora28 » Wed Jul 28, 2004 5:49 pm
Howdy, yeah I put rack n pinion in my RA28 Celica. The problem is the rack is slightly too wide (around 30mm), I could shorten it but figured it would be worth looking into other setups.
The RWD starlet is a small car I figured and might have a skinner track than the AE86/KE70 rack I currently have.
But yeah, we didn't get any here :(
Mate the TA63 rack is pretty wide, I assume you'd be extending the pivot points for the control arms outbound so you don't have bump steer issues?
Joel
turbora28
Postby wde_bdy » Wed Jul 28, 2004 6:21 pm
turbora28 wrote:Mate the TA63 rack is pretty wide, I assume you'd be extending the pivot points for the control arms outbound so you don't have bump steer issues?
Joel
I have the complete front AND rear end (IRS) in the car so pretty much all stock geometry for the TA63 except for a little bit lowered. My car has very little standard stuff left in it.
Callum
wde_bdy
Postby turbora28 » Wed Jul 28, 2004 7:45 pm
Ahh ok cool, no probs then.. I looked at this also (front end), but looked like it'd make my track too wide for the wheels to clear the guards.
Would have been a shit load easier though i reckon.
You got some flares?
turbora28
Postby wde_bdy » Wed Jul 28, 2004 9:09 pm
Not yet but definitely required.
http://www.imagestation.com/album/?id=4287661413&code=8392016&mode=invite
You may need to copy and paste the link.
Callum
wde_bdy
Users browsing this forum: Google [Bot] and 1 guest
