aw11 suspension mods - any sugestions?
Postby mr20v » Thu Aug 05, 2004 12:37 pm
My aw11 currently has crazy hard springs and the shocks are a bit past it. I want a more pliable suspension set-up but still all low and racecar-like.
Before any one asks I have no idea what the spring rates are.
Are a nice set of coil-overs the way to go?
Do you need too get them certed?
'84 20V AW11
'89 FX-GT w/ half-cage (MADFX - anyone want to buy a number plate?)
Click here for fancy porn!
mr20v
Postby Mr Revhead » Thu Aug 05, 2004 2:19 pm
hello
first up yes coilovers need cert.
secondly it all depends how low you want to go.... i can do kits from stock to as low as you can go... a spring set will cost from $380-475 and covers ranges from 20mm to 40mm lower. which in an aw11 is probably enough,
Postby Virtual Genocide » Thu Aug 05, 2004 3:09 pm
this might be of some help:
http://shell.deru.com/~sgn1/AW11/Suspen.htm
its a good all-round aw11 site
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby lvn_mr2 » Thu Aug 05, 2004 9:14 pm
why not some KYB 4-way adjustibles, SuperCharger stock springs and TRD stage 1 wheel alignment.
works wonders for me :D
lvn_mr2
Postby MR2boy » Fri Aug 06, 2004 9:52 am
lvn_mr2 do u have a link to those specs?
MR2boy
Postby lvn_mr2 » Fri Aug 06, 2004 1:35 pm
for the TRd alignment specs?
i have them written down somewhere....i'll look tonight, otherwise i got them from the MR2 message board!
lvn_mr2
Postby Mr Revhead » Fri Aug 06, 2004 1:41 pm
TRD alignment specs?? thats a new one to me... are they the specs they provided with their bush kits or something?
Postby lvn_mr2 » Fri Aug 06, 2004 7:55 pm
heres the specs:
alignment:
Camber Front: -1 degree
Camber Rear : -1 "
Caster : +6 "
Toe in Front: 1/16 in.
Toe in rear : 1/8 in.
this is the specs that TRD would set-up the suspension for phase (stage) one. there were three stages, but this seems the best street set-up. phase two is more auto cross/stree and phase three is full on track style.
phase one works very well for me, although ride quality was slightly less than stock, it is still nice to drive and handles very well and my breaking distance has shortened :D
don't know if this is the same on the 84 (ride quality and stuff) but the specs are the same for all years of aw11. this set-up is currently in my 89 and can strongly recommend it :D
HTH, Good Luck
lvn_mr2
Postby mister2 » Sat Aug 07, 2004 4:02 pm
hey man,
heres the link to the alignment specs lvn_mr2 mentioned:
http://www.mr2.com/TEXT/MkI_TRD_Prep.html
also lists some other interesting stuff, that was the alignment i had your car set to lol :)
yeah those springs are damn hard.
i got the coil-over kit from japrace, also my car had GAB 4-way's in it, but both of the back ones crapped out (one leaked, the others adjustment knob seized) so its only got those in the front. however i really havent had my car on the road enough to get it handling right!!
check http://www.mr2oc.com/forumdisplay.php?s=&forumid=55 which is appropriately named, mk1 suspension forum (;)) theres a lot of good information on here, even though you have to wade through a lot of crap.
nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Mr Revhead » Mon Aug 09, 2004 2:19 pm
ah from TRD-USA
they have different stuff from TRD in japan, mainly us market stuff.
