Adydas wrote:look dont make me hit you to together..
2 penisis touching like thats just ghey
kingcorolla wrote:i think it works like, when you launch, the controller precicely misfires at certian points to control wheel spin,
This is very effective on forced induction because the missfire causes a change of heat and pressure differential across exhaust turbine, and therefore turbo spools up FASTER.
matt dunn wrote:kingcorolla wrote:i think it works like, when you launch, the controller precicely misfires at certian points to control wheel spin,
Dont mix up traction control and launch control as they are different.
Launch control is just a clutch activated rev limiter that can be adjusted.
Traction control requires wheel speed sensors and launch control does not.
Bazda wrote:Adydas wrote:look dont make me hit you to together..
YUCK
Users browsing this forum: Bing [Bot] and 61 guests
