10mm Leads for 20v
10mm Leads for 20v
Postby 2Fast4vtec » Fri Aug 20, 2004 3:47 pm
Hey does anyone know where you can buy good 10mm leads for 20v's from?
2Fast4vtec
Postby rollas22 » Fri Aug 20, 2004 4:15 pm
im with you on that...... Maybe TRD make sumthing??
KE-Corolla's for life!!!
rollas22
Postby sixspeeder » Fri Aug 20, 2004 4:21 pm
let us no when you suss some, ill be keen
price etc
meh
sixspeeder
Postby Mr Revhead » Fri Aug 20, 2004 4:22 pm
they certainly do!
pm me if ya want some!
Postby AceSniper » Fri Aug 20, 2004 4:50 pm
thought TRD only made 5 or 7mm ones?
I found some NGK hyper silicon ones but they are 5mm aswell
AceSniper
Postby FLAWLES » Fri Aug 20, 2004 6:39 pm
yea same wot give mr rev head????
i could only find ngk ones as well i was kinda hoping splitfire do them :lol: to be honest i havent tried for them yet :lol:
FLAWLES
Postby TRD Man » Sat Aug 21, 2004 12:29 pm
TRD leads forv 20V are 5mm. Size doesn't always matter.
TRD Man
Postby ROBODISCO_20v » Sat Aug 21, 2004 5:55 pm
Lead size dosent make any diiference to the spark. All it is, is more insulation from heat to stop them breaking down as quickly. You cant get 10mm lead for 20v's off the shelf. you can get 5mm from anyshop in nz & 7mm ex japan that cost over $300. The problem is their special ends where they go into the dizzy. Now if you're running an aftermarket ECU like a link etc you can the run individual coil packs like the ae101 GTZ does. Then you can get some custom made lead to any size you want.
Did some one see the blue AE86(nite parts) at the drags with the silvertop 20v running 10mm leads?? this is the set up he has. Brendon & I made the leads at my work.
ROBODISCO_20v
Postby AceSniper » Mon Aug 23, 2004 7:08 pm
FLAWLES wrote:i could only find ngk ones as well i was kinda hoping splitfire do them :lol: to be honest i havent tried for them yet :lol:
http://www.interone.jp/~balance/history ... 020808.htm
I know splitfire do them for 20v's
I had some from repco then came accross the NGK ones on trademe near new for $40 .... wayyyy better than the champion ones
AceSniper
Users browsing this forum: No registered users and 36 guests
