little help needed link ecu and 4agze
Postby dohca » Sat Aug 28, 2004 8:21 pm
gidday guys
i need a hand with people who have used a lem ver4 wire in unit with a 4agze out a ae92
did you have to use an extra resistor block?
how did you wire yours?
also whats the firing order of a 4agze
dannyp
dohca
Postby RedMist » Sat Aug 28, 2004 9:32 pm
I run the ZE DLI dizzy with WRX coils and 20 valve injectors. The injectors don't have a resistor inline, however your ZE injectors are low impedance which from memory will mean you have to put a resistor in line. I also run what I presume is another resistor pack on the coils for flyback (Columbus Car Clinic installed this, it might be a cap, I should check!)
Wiring is pretty straight forward. It's detailed in the LEM 4 manual, however you'll need an additional page from Link for the DLI trigger set.
I used a thermostat in the radiator to trigger the fans and used the fan output on the Link to trigger an over temp warning LED.
I also used the two additional RPM triggers to give me a staged shift light in two large LED truck side markers (might be a little big for a car, when lit at night I doubt you'll be able to see out of the windscreen)
1-3-4-2
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby dohca » Mon Aug 30, 2004 12:00 am
what igniter did you use?
dannyp
dohca
Postby RedMist » Mon Aug 30, 2004 7:55 am
As I'm running the WRX coil set in a wasted spark solution I had to run the dual channel link ignitor. (M and W ignitions from Ausi). You'll be forced to do the same with the ZE coils.
RedMist
Postby 10k 20v » Mon Aug 30, 2004 7:20 pm
Or a cheaper solution is to get an igniter from a wrx, evo or similar.
The mitisi ones also have a tacho output where as the subaru doesn't.
Make sure you get the plug.
I'm running the wrx type myself
10k 20v
Postby 4ageturbs » Thu Sep 02, 2004 8:24 pm
mines a vr4 igniter
4ageturbs
