Is there any difference
Postby 1goodidea » Mon Aug 30, 2004 11:52 am
Is there any difference between
2k and 4k carb and intake manifold?? (single carb not twin)
AND
4k exhuast manifold and 2k exhuast manifold?
1goodidea
Postby Muzzie » Mon Aug 30, 2004 11:57 am
If you got a 2K intake / exhaust manifold handy i can source ya pics of my 4K if that helps.
No idea if they're interchangeable though.
*note to self - learn some more stuff!*
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby 1goodidea » Mon Aug 30, 2004 12:35 pm
Muzzie wrote:If you got a 2K intake / exhaust manifold handy i can source ya pics of my 4K if that helps.
Yip that would be great!
check your PM's
1goodidea
Postby Muzzie » Mon Aug 30, 2004 1:25 pm
Have done, and I have sent you 3 pics from varying angles, with the air filter assembly removed. Hope they help :)
Muzzie
Regular Poster
Re: Is there any difference
Postby kingcorolla » Mon Aug 30, 2004 2:19 pm
1goodidea wrote:Is there any difference between
AND
they are indeed interchangeble 8)
1983 Carina AA63 4age
kingcorolla
Postby 1goodidea » Mon Aug 30, 2004 2:57 pm
AND
yeh i no that, just wondering if there are different at all, ie would a 4k run just as well with a intake manifold and carb of a 2k
1goodidea
Postby kingcorolla » Mon Aug 30, 2004 3:24 pm
im about 95% sure it will runn fine, as the difference between the two is the displacement in the the block, head and pushrod length. im pretty sure the carb/manifolds are the same.
kingcorolla
Postby starlet drifter » Mon Aug 30, 2004 7:20 pm
the only head that would be differnet is the 3kb head, and the k and2k one, cause they dont hav factory vacuum feeds for the brake booster (ke20s and 10s didnt hav booster factory.)
mmm 4age kp starlet :D
starlet drifter
