So has anyone taken the cluster out on these? I havent tried doing it as yet but just thought id check to see if there are anything to watch out for. Any tips would be good, maybe even a step by step guide if your real keen
acesniper wrote:might be just as easy to drop the wires behinde/in the dash an wire it into the tach wire on the ecu prolly eayer to find.
aesc wrote:I have ordered a shift light which should be arriving this week and I am going to need to take out the instrument cluster to get a tacho signal and feed wiring through too as im not keen on having wires visible running over my dash
So has anyone taken the cluster out on these? I havent tried doing it as yet but just thought id check to see if there are anything to watch out for. Any tips would be good, maybe even a step by step guide if your real keen![]()
Loudtoy wrote:You could go behind the dash or to the ecu as someone else said they both about the same deree od dificulty to do so up to you if you like lying down or siting upright while you do it!For the wire to tap into if it's a gizzmo unit use the one they recomend on the wiring diagram
minijrocks wrote:just mount it to the right and tap into the "electric mirror" console bit. and trhen get the coil from the engine bay (this is easy i got pics - fool proof). My wires just hide under the elec mirror bit that clips back in, doesn't look to bad and no drilling. only took me about an hour.
