the ehad gasket will be the least of your worries. Feel free to jack the boost up, but just be careful about it. Dont be one of those idiots that manages to blows engines/melt pistons due to idiocy. Keep a careful eye on your air/fuel, and listen to what your engine tells you. The likelyhood of blowing a h/g is minimal.stephen bedford wrote:hey yo'll i got a 1990 gt starlet and running 10pounds at the moe, im wanting to tickle this up a bit more i iwll be putting in a front mount(from sss attessa bluebird(coz its black and inconspicuous) so i can crank it up a bit more all ive done is put a bleed line in the actuator line, but ive herd much more boost than 11ish will pop a head gasket whats the go???????
