ChaosAD wrote:No good for a 4agze, wont rev any better cos of the s/c and run very well either.
4AGTE wrote:By to much tourqe i was starting in second at the drags and was still wheel spining way more than anyone else till about 90 in second. Dont ask about first.
4AGTE wrote:You can increase the troque of your car down low with more fuel and in doing this kill top end. You can also kill top end power and give more mid range/bottom end with adjustable cam pulleys. Their for this can work both ways. Do you care to explain this?
I could be wrong on this also
Mr Revhead wrote:or you could play with other aspects of the engine, such as intake design injector placement etc etc
but i think the point you are trying to make is changing the flywheel to alter the torque wont work, which is correct
4AGTE wrote:If i have a lightend fly wheel this will kill bottom end will it not and help it in the high end rev's?
Torque and hp are directly linked and you canot change one with out the other being different right?
But you can change your tourqe/hp down low with cam gears/ fuel ratios.
Is this not right?
Users browsing this forum: No registered users and 61 guests
