180 km/hr speed limiter
Postby MetalupYoAss » Sat Sep 04, 2004 1:07 pm
tried and tested on silvertop and bluetop 4age, 4agze will be the same... the engine check light comes on to indicate that theres a problem and the ecu controlled redline might be about 500rpm less than what it should be, but it wont go into limp mode (3500 rev limit and rich as mixture) i assume it will be the same on a 1ggte, it might not be.. might aswell try it anyway to see what happens before forking out like 200 bucks
MetalupYoAss
Postby sprint » Sat Sep 04, 2004 2:45 pm
Cheers will give it a go.
Old Rides:
88 GZ20 Soarer 1G-GTE
81 Ex Lancer
sprint
Postby matt dunn » Sun Sep 05, 2004 1:14 am
Al wrote:
MetalupYoAss wrote:find the purple wire with a white stripe that goes into your ecu and put a switch on it, when the switch is closed the car will act like normal with the speed cut but when you open it the engine check light will come on but you can go over 180... no need for expensive gadgets
Is that tried and tested? Because usually when CEL comes on you go into limp mode.
Yes. I have done this to a few cars and no problems.
The speed sensor is not a vital controll input and so it will bring on the light but will not cause problems other than stalling sometime when you come to a stop.
I have done this to my AE92 GTZ and parents ST165 GT 4.
Matt
Postby IH8TEC » Sun Sep 05, 2004 2:11 am
Matt
hey matt, is there only one wire that is purple and white, on an ae92gtz. and how had is it to get to the ecu and the wire. is it better to do it under the dash, or can you get to it somewhere else? i have a switch wired in my car being used for nothing at the moment, could be fun.
Postby MetalupYoAss » Sun Sep 05, 2004 12:00 pm
easiest to access the wire at the ecu end you might have to un-wrap a bit of the tape to get to it
MetalupYoAss
Postby FLAWLES » Mon Sep 06, 2004 6:55 pm
thaphatty wrote:hahaha! thats great! damn you crazy! anyone who wants to take off their speed limiter is my kinda person :twisted:
i dont need a speed limiter on the ze there freekin bad when you hit them it feels like the car is going to float away :? looks at the phatty and nods
you no what im talking about
any one no how much $$$$$ ??????
FLAWLES
Postby matt dunn » Mon Sep 06, 2004 8:22 pm
MetalupYoAss wrote:easiest to access the wire at the ecu end you might have to un-wrap a bit of the tape to get to it
For the not so mechanically or electrically minded it may be easier to locate it at the speedo itself.
I do not know if there is more than 1 wire that colour.
Postby IH8TEC » Mon Sep 06, 2004 8:47 pm
yeah i had a look yesturday at the ecu, it's on the plug closest to the seats, i could only find one that color, doesn't look too hard to get at form there. will give it a go soon.
Postby MetalupYoAss » Mon Sep 06, 2004 9:46 pm
nah, theres usually just the one purple/white wire...
MetalupYoAss
