an if so... who sells 4wire sensers at an "ok price" and have them in stock
thanks
AceSniper wrote:mm that may do the trick? Its odd tho only done it in the cold... ill try turning my lights off see if it changes(look out for the ae101 in the dark) but anyway... I pulled it out today... had abit of carbon buildup on the base but nuthen bad turned it on an it felt to be getting warm but very very slowly
AceSniper wrote:yea there are two black oxy wires the bottom one been the + for the heater or sumthen? Iv taped into the center plug 3rd wire at the top. Just went to taupo and around half way there I got some proper readings that stayed around the 14.7 so im guessing the heater in it is screwed coz at the start of the trip ham-cambridge it read lean then it started reading but all over the place.
