what is a "top tank"
Postby Sanxta » Tue Sep 21, 2004 6:38 pm
yeah - what is a top tank on a radiator and what does it do?
cheers,
adam
Sanxta
Postby kingcorolla » Tue Sep 21, 2004 7:29 pm
just a hollow plastic/brass tank, that joins the radiator tubes to the bottom tank. they hollow so water can flow in and out of the tubes in radiator.
what the top hose joins on to..
1983 Carina AA63 4age
kingcorolla
Postby Sanxta » Tue Sep 21, 2004 7:32 pm
know where i can get one cheap but good?
the fixed pipe on the top of my radiator came off inside the flexi-pipe. dunno what to do about it ?
Sanxta
Postby kingcorolla » Tue Sep 21, 2004 7:48 pm
easy! dont get a new tank.. just take it to a radiator specialist, and get them to weld it back on!
kingcorolla
tank
Postby JasonZE » Tue Sep 21, 2004 9:32 pm
If its a plastic you cant weld it and you need a new tank $200+ or get a s/h radiator.
JasonZE
Real Life Mechanic
Re: tank
Postby kingcorolla » Tue Sep 21, 2004 10:01 pm
JasonZE wrote:If its a plastic you cant weld it and you need a new tank $200+ or get a s/h radiator.
would plastic welding not do the trick???
kingcorolla
Postby blitza » Wed Sep 22, 2004 5:23 am
can do, not many ppl would be keen to do it but, can't provide any warranty.
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby Sanxta » Thu Sep 23, 2004 11:49 am
yeah, prolly keener to do it properly with a replacement brand new.
what do you mean by "s/h radiator" ?
Sanxta
Postby JT » Thu Sep 23, 2004 12:04 pm
second hand
JT
Postby Sanxta » Thu Sep 23, 2004 12:12 pm
oh yeah *duh* @ me
um yeah, pretty dodgy considering cooling system water skankiness . . .
Sanxta
Postby kingcorolla » Thu Sep 23, 2004 1:33 pm
.. just drop it off at the doctors before u put it in then..
save ureself from getting a R.T.D (radiator transmitted disease)
kingcorolla
