Leon wrote:If you have an O2 sensor, using leaded fuel will cause it to stop working.
Also, its probably a total waste of money, unless you are running a lot of compression (or boost).
Bazda wrote:i never knew that a o2 sensor bungs up using leaded fuel, as when the cars were made 96 octane was leaded
RunningRich wrote:
Then you are sadly uninformed. 96 may have been leaded in NZ, but these cars were not made for our market. NZ new models (like AW11 etc) had no O2 sensor.
Leaded fuel *will* kill an O2 sensor.
matt dunn wrote:Yes nz new models had a mixture adjustment screw instead of a O2 sensor because of lead.
The falcon leaded sensors are lead resistive non lead capable.
They are expensive compared to normal but do last for ages on lead
(but not forever )
Al wrote:Where do i get a lead friendly o2 sensor?
I've run about half a dozen tanks of racegas since ive had the car....*touch wood* hasnt pulled any codes yet
