No idle??????
No idle??????
Postby sprint » Thu Sep 23, 2004 12:54 pm
I've just replaced my engine (1G-GTE) with a Gen 3 Manual engine and are still using the auto Gen 2 wiring loom and ecu. When i start the car it runs for a few seconds and then dies. You can keep the engine going by giving it some gas but as soon as you stop it dies. I think it may be not runnnig any idle bypass at all? Anyone got any ideas or had this problem before, would appreciate any help.
Old Rides:
88 GZ20 Soarer 1G-GTE
81 Ex Lancer
sprint
Postby Ae92typeX » Thu Sep 23, 2004 8:49 pm
Have you adjusted the idle screw at all?
When I did my conversion I made a small adjustment to it. Also, my bov (external venting) was on a soft setting. It didnt prove an issue when auto, but once manual it caused the car to idle rough and stall.
Did you clean out the bi-pass hose at all?, mine was fully clogged up. Dunno if it will make a difference as I cleaned mine while the engine was out and in parts.
Ae92typeX
Postby sprint » Fri Sep 24, 2004 10:30 am
Yeah i have tried the idle control but it doesnt help. It is giving me error's 24 and 31. So im going from there.
Old Rides:
81 Ex Lancer
sprint
Postby Ae92typeX » Fri Sep 24, 2004 9:37 pm
Not to help you one bit, but do you have a copy of the error codes for the 1ggte?. I dont have any errors, but it would be handy to have a copy of the codes. I used to have a copy, but dont anymore :cry:
Ae92typeX
Users browsing this forum: No registered users and 35 guests
